Toliet Flange Clicking Noise
Old 02-10-2004, 09:04 AM   #1
Unregistered
Guest
Unregistered's Avatar
Posts: n/a
I have been replacing the flooring in my upstairs bathrooms . I have replaced the sub-floor and installing new ceramic tile instead of the old linoleum flooring. There was some play in the toilet flange and I was able to pry the flange enough to get the tile installed. However after I have finished the flooring we now seem to have developed a clicking sound in what appears to be the drain pipe whenever the water is running in a near by sink or when the toilet is flushed. The drainpipe is PVC and I didn’t know if I could easily replace the flange.
Old 02-23-2004, 03:30 PM   #2
Unregistered
Guest
Posts: n/a
Re: Toliet Flange Clicking Noise
I have the same kind of noise in my bathroom. I was told that it is because a pipe is pressing up against something, probably a part of the floor or wall. When the water runs through it, the pipe moves a bit and that makes the clicking noise. I've been told that it isn't a huge deal and not to worry about it. (Whether that is true or not, I can't say, but I do trust the source -- mostly.)
Old 07-20-2004, 11:15 PM   #3
plumber79's Avatar
If the clicking is greater when the hot water is operated, it is expansion and contraction of the pipe when the warmer water reaches that area. It will click or sound like a drip as the water is running and for minutes after it is turned off. Not a problem but is annoying. Probably happened when you moved the drain up to clear the tile. Fix? You know better than I how to correct it as you live it.
plumber79 is offline
Old 07-21-2004, 09:38 AM   #4
Custom Builder
Glasshousebltr's Avatar
If the clicking noise co-insides perfectly with your watch, and if you first noticed the clicking noise after an Arab friend used the crapper, and also if that Arab friend has a pilots license.....Run now.
Bob
Glasshousebltr is offline
Old 07-21-2004, 09:45 AM   #5
Custom Builder
It's the PLO ....Poop Liberation Organization.
Bob
Toilet and the Flange troyamuso Kitchens & Baths 22 04-02-2007 01:50 AM
Toilet flange C.C.R. Plumbing 11 01-06-2007 02:48 PM
Tapping noise ... RobertWilber Electrical 3 09-07-2006 07:22 PM
Furnace-gas forced air- high pitched noise saturn711 HVAC 3 03-25-2006 09:52 PM
closet flange Vermonster Plumbing 3 02-15-2006 08:43 AM
