Trade: Residential Building & Remodeling
Toilet Problems
Hey everyone,
I recently remodeled my in-laws master bath and now we are experiencing strange toilet issues. The original toilet was set at a 12" rough-in, but when the plumber's helpers came out to relocate the supply and drain lines for the vanitys they also reset the toilet at a 10" rough. The flange is still in the same place, just 2" closer to the wall. So, we ordered an American Standard Cadet with a 10" rough-in. The specs call for a 9"x11" water table but it will hold water only to about a 2"x3" table, and when the bowl does fill to the proper height it's only a matter of minutes until it's almost empty. We have no leaks. The vents are properly sized and are clear. The original toilet operated just fine. We thought it was a faulty toilet, but we've bought another brand/model and the problem is still present. FYI, they are on city sewer. Thanks
Trade: Plumbing & Electrical
Re: Toilet Problems
So it's just the bowl water that drains out, or is the tank draining out too, and the valve refilling?
Is the floor level? |
Re: Toilet Problems
Floor is level and the water only drains from the bowl.
Plumber
Trade: Plumbing
Re: Toilet Problems
A water closet will do the same thing if there is a stoppage in the line causing it to siphone out , you had mention the second one you installed did the same thing .
| Is everybody using the toilet gaurd to keep subs from peeing in the toilet? | Mike Finley | General Discussion | 38 | 03-17-2008 10:36 AM |
| Toilet Challenge | Vermaraj | Plumbing | 40 | 11-09-2007 09:04 PM |
| Portable Toilet | AFI | Painting & Finish Work | 32 | 10-23-2006 12:19 AM |
| Doh! Toilet installation options... | Big E | Plumbing | 7 | 07-25-2006 04:18 PM |
| proper job replacing toilet? | soxfan | Plumbing | 4 | 12-31-2005 01:12 PM |
