Toilet-Issue Slow Trickle
Old 01-12-2008, 05:12 PM   #1
FRAME ON!
A+Carpenter's Avatar
Trade: Decks,All phases of remodeling,
My toilet is trickling still after the process after filling back up.
I checked everything on the unit and all looks good. It is a slow down the side of the bowl trickle.
I turned off unit to conserve water awaiting a response. I am a carpenter not a plumber.
Thank you in advance,
Crosswinds Construction
Houston TX
A+Carpenter is offline
Old 01-12-2008, 05:13 PM   #2
The Grand Wazoo
KillerToiletSpider's Avatar
Re: Toilet-Issue Slow Trickle
It needs a new flapper.
KillerToiletSpider is offline
Old 01-12-2008, 05:18 PM   #3
FRAME ON!
You know what that is the only thing I did not check.
Considering that is what feeds the supply for outflow you are correct.
Is everybody using the toilet gaurd to keep subs from peeing in the toilet? Mike Finley General Discussion 38 03-17-2008 10:36 AM
Toilet Challenge Vermaraj Plumbing 40 11-09-2007 09:04 PM
Toilet Problems McCall Builders Plumbing 4 01-31-2007 08:24 AM
Slow toilet/ weak flush paintr56 Plumbing 14 06-13-2006 06:11 PM
proper job replacing toilet? soxfan Plumbing 4 12-31-2005 01:12 PM
