Toilet Hookup
Old 06-18-2017, 09:41 PM   #1
christoff's Avatar
Trade: home renovations
Rewards Points: 150
Toilet Hookup
We were down in Charleston South Carolina for the past week and stayed in the Sleep Inn in Mt. Pleasant. I flushed the toilet and the flapper was stuck open so I took the top off and reached in to untangle the chain when I felt hot water, yup the water supply was hooked up to a hot water source. The payoff was on top of the toilet it had a sign that read lets do our part to conserve energy
christoff is offline
Old 06-19-2017, 07:06 AM   #2
John the Builder
SmallTownGuy's Avatar
Trade: Carpenter/Builder
Rewards Points: 6,970
Re: Toilet Hookup
I'd bet though that the stool wasn't sweating or condensing/dripping.
Frederick Law Olmsted - America's First Landscape Architect
SmallTownGuy is online now
The Following User Says Thank You to SmallTownGuy For This Useful Post:
hdavis (06-24-2017)
Old 06-19-2017, 07:24 AM   #3
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 4,923
Re: Toilet Hookup
Maybe there's some logic to the set-up since the rooms are piped to supply instant hot water (cycling water all the time).
MarkJames is online now
Old 06-19-2017, 04:15 PM   #4
The Grand Wazoo
KillerToiletSpider's Avatar
Rewards Points: 1,832
Re: Toilet Hookup
There are pressure balanced T/S valves that can internally fail and allow hot water to pass through to the cold side without any sign of the valve leaking otherwise. My guess would be that is what is happening here.
KillerToiletSpider is offline
The Following User Says Thank You to KillerToiletSpider For This Useful Post:
MarkJames (06-19-2017)
Old 06-19-2017, 06:41 PM   #5
christoff's Avatar
Rewards Points: 150
Re: Toilet Hookup
You mean that there is a ts valve on a toilet water supply valve?
The Following User Says Thank You to christoff For This Useful Post:
phr2 (06-21-2017)
Old 06-19-2017, 08:28 PM   #6
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 7,958
Re: Toilet Hookup
I think he is referring to a bathroom piped with a trunk and branch supply, and on the same trunk there is a Tub/Shower mixing valve with pressure balancing spools that are bunked and causing hot and cold to mix.
Inner10 is offline
Old 06-19-2017, 08:43 PM   #7
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 766
Re: Toilet Hookup
Exactly. I got called to a commercial facility, where they couldn't get hot water at several fixtures. I went into the kitchen where they had a sink faucet with a separate hot and cold valves, and then a single valve after those. Hot and cold stayed on always, and they just shut off the main. I shut the hot and cold valves off, and Voila, hot water to the whole facility.
I actually one time accidentally piped hot to a toilet. It was an addition, and somehow or other I grabbed the hot and ran it to the toilet. Everything else was fine, of course. Didn't know till the very last thing. Hooked everything up and left. They called me the next day and said, "I think the toilet is filling with hot water".
That was my "Oh $#!T moment for the year.
Delta
There's fast, there's good, and there's cheap. You can pick one, sometimes two, but never all three.
Old 06-20-2017, 07:22 PM   #8
SectorSecurity's Avatar
Trade: Low Voltage Wiring
Rewards Points: 1,598
Re: Toilet Hookup
When they plumbed my parents house in Florida they piped hot to the toilet by mistake **** happens
Sent from my XP7700 using Tapatalk
SectorSecurity is online now
Old 06-21-2017, 06:01 AM   #9
Big Johnson's Avatar
Rewards Points: 541
Re: Toilet Hookup
I remember as a kid hearing people recommend running hot to the toilet. I think it's was home improvement shows on PBS and Bob villa. It must have been repetitive for me to remember it after all these years. It was before low flush toilets and all this global warming hysteria.
To prevent sweating.
Big Johnson is online now
Old 06-24-2017, 03:43 AM   #10
Ernie in Dawson's Avatar
Trade: Plumber/Gasfitter
Rewards Points: 56
Re: Toilet Hookup
It is probably like was said about the tub mixer being faulty but who knows.
I got called to a house one time that was 3 years old and the original owner never used his icemaker or his DW. Turns out when the new owners moved in, the DW was connected to the cold water and the fridge line to the hot water. One of our apprentices had done the work and I razzed him for quite some time on that blunder.
Ernie in Dawson is offline
Toilet dollys platinumLLC Tools & Equipment 17 01-16-2015 07:25 PM
Toilet Mystery carolinahandyma Plumbing 9 01-05-2013 04:50 PM
Is Access to a Toilet a ‘Basic Human Right’?: (This isn't a joke!) MAULEMALL Off Topic (Non Trade) 50 05-28-2012 02:42 PM
Easy, toilet replacement fireguy Plumbing 21 05-12-2011 08:03 AM
Toilet Challenge Vermaraj Plumbing 40 11-09-2007 08:04 PM
