Toilet Flange To Service Pipe
Old 04-19-2006, 08:33 AM   #1
Scaper's Avatar
Trade: Landscaping/Mowing Services
Send a message via AIM to Scaper
Question
Found a leak and pulled toilet. Flange to service pipe is PVC and broke where the two bolts connect flange to toilet fixture. PVC Flange is one piece with service line and entire line seems to be connected to entire system. What is the best fix for replacing flange?
Scaper is offline
Old 04-19-2006, 04:20 PM   #2
IHI's Avatar
Re: Toilet Flange To Service Pipe
Can you see main line where the toilet flange/pipe run into? Is it easily accessible so you can cut the flange/elbow and a short bit of line completely out and then splice in new stuff?
They also make a cutter than you can chuck up in your drill that will cut the PVC from inside the flange, but if your's is indeed 1 piece I cant imagine after removing the flange only the OD or ID of what's left would hook right upto standard fittings-it might/should, but it's hard to say without seeing it
IHI is offline
Old 04-19-2006, 04:51 PM   #3
ch0mpie's Avatar
Trade: Geotechnical PE
They make a "flange repair fitting" I'm not really sure what the technical plumbing supply house word for the this is, but basically it is a flange with about 4 or 5 inches of pipe on it. This part fits over the broken flange and inside the existing pipe and has a couple of gaskets around it. It has screws in it you crank down on so the pipe expands and seals the gaskets.
Kind of hard to explain, but ask about it at your local supply.
ch0mpie is offline
Old 04-19-2006, 05:35 PM   #4
Plumber / Carpenter
Bill's Avatar
Trade: Virginia Building and plumbing contractor
Send a message via Yahoo to Bill
There are a variety of flange repair kits available. Go to any HD or Lowe's and check them out, I'm sure you can find one that you feel comfortable with and most all do not require a great deal of plumbing knoledge to install
Is it beer thirty yet
Virginia Department of Licensing
Virginia Plumbing Codes
Bill is offline
Old 04-25-2006, 04:18 PM   #5
Scaper's Avatar
Thumbs up
I was able to use a cutting blade on a Dremmel tool and score the old flange piece vertically about a 1/4" deep, up the entire length of the old PVC flange adapter. I then used a chisel and popped the old, broken PVC flange off of the service pipe, allowing for the replacement of a new, steel ring/PVC closet adapter to service pipe! Worked like a dream and now we have a closet flange with some integrity! Thanks again for advise!
Scaper is offline
Toilet Challenge Vermaraj Plumbing 40 11-09-2007 09:04 PM
Toilet and the Flange troyamuso Kitchens & Baths 22 04-02-2007 01:50 AM
Toilet flange C.C.R. Plumbing 11 01-06-2007 02:48 PM
New help with this toilet flange Mike Finley Plumbing 2 06-16-2006 09:27 AM
Set-Rite - Toilet Flange Spacer System The Inspector Plumbing 24 10-13-2005 10:38 PM
