Toilet Bowl Stain
Old 12-09-2017, 04:01 PM   #1
royceGC's Avatar
Rewards Points: 16
Toilet Bowl Stain
Hi to all!
I'm having an odd stain/growth issue in my own home!
In the of my toilet bowls, a grayish/brown growth is occurring.
It starts out at the front end of the bowl just at & below the water line.
It rapidly gets larger.
It forms at several points under the water in the bowl, at various points in the bowl.
If I clean it, it reforms in 2 days.
The 2nd floor bowl is a cheap bowl, I have changed all of the internals, and if left unchecked the bowl inside is a solid mass of grey. It first started in the that toilet and had been going on for about a year but its gotten pretty bad.
The 1st floor is a Toto. It just started to develop that same symptom about 2 months ago.
Internals have been changed in that bowl as well.
Nothing in either shower nor either sink.
The bowls have been in use for 15 years.
Piping is all copper with a small, canister style whole house water filter which , also, has been in use for 15 years.
I am baffled. Never seen anything like this.
royceGC is offline
Old 12-09-2017, 04:29 PM   #2
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 10,631
Re: Toilet Bowl Stain
It looks like something is living in the guts of the flush, like everything below the flapper, down to the jet hole.
How about this? Drain the bowl, plug the jet hole, then pour a bleach solution down the flush valve hole. Some will pour out the rim holes (unless you block those, too). Let it sit for a while to kill what's in there.
Or just dump some bleach into the bowl every once in a while to see if it makes a difference,
Or get new toilets.
MarkJames is offline
Old 12-09-2017, 05:54 PM   #3
rselectric1's Avatar
Rewards Points: 532
I would have your water tested. I have a similar issue and it's due to the water quality. Not much I can do about it since I'm in a condo environment, but at least you'd know why.
rselectric1 is offline
Old 12-09-2017, 06:41 PM   #4
hdavis's Avatar
Rewards Points: 3,449
Looks like a water issue to me.
FWIW, the bowl rinse passages are almost never cleaned.
hdavis is offline
Old 12-09-2017, 08:05 PM   #5
DaVinciRemodel's Avatar
Trade: Design/Build Remodeler
Rewards Points: 208
Is that something growing or is it sediment? Do you have to scrub/scrape it off?
I love what I do and I'm very good at it!
Da Vinci on the web or Da Vinci On Facebook
DaVinciRemodel is offline
Old 12-10-2017, 08:10 AM   #6
royceGC's Avatar
Rewards Points: 16
It's definitely something growing....not sediment.
Without a new flush it multiplies rapidly....and a new flush will not remove any of it.
It has to be scrubbed off.
The 2 toilets have nothing in common except the water supply.
The odd thing is that it doesn't appear in any porcelein sinks.
Ive been in literally thousands of homes....as a GC and as an Inspector, and Ive never seen this.
royceGC is offline
Old 12-10-2017, 08:23 AM   #7
John the Builder
SmallTownGuy's Avatar
Trade: Carpenter/Builder
Rewards Points: 7,256
mold mildew or algae chlorine bleach kills 'em all.
Might be getting transferred by toilet scrub brush one fixture to next.
Might be in water lines - UGH.
Net Zero Energy Is Here Now
“The worst day working for yourself, is still better than the best day working for someone else!”
..Jim Rohn
SmallTownGuy is online now
Old 12-10-2017, 09:38 AM   #8
kirkdc's Avatar
Trade: Remodeling (mostly kitch/bath)
Rewards Points: 1,746
I've seen this before, caused by over-consumption of habanaro burrito's.
kirkdc is offline
Old 12-10-2017, 09:47 AM   #9
Rewards Points: 208
Burned right through the porcelain
Old 12-10-2017, 11:17 AM   #10
This space for lease
RangoWA's Avatar
Trade: Tool jocky
Rewards Points: 2,066
I have nothing to add about the source, but I have to be kind to my waste water since I'm on a septic system so harsh chemicals are out. We get calcium deposits here and I tried the pumice stone but notice they scratch the porcelain so I tried wet/dry sandpaper. Worked great and made short work of it. I hit it with 220 then 400.
RangoWA is offline
Used toilet refund Chenyi General Discussion 17 12-16-2016 09:33 AM
Setting a toilet Morning Wood Plumbing 49 08-10-2015 05:48 AM
Toilet dollys platinumLLC Tools & Equipment 17 01-16-2015 08:25 PM
My photos from the Super Bowl yesterday 480sparky Off Topic (Non Trade) 9 02-05-2013 09:34 AM
H and C acid stain Traditions2 Painting & Finish Work 1 02-05-2009 08:27 PM
