Tilted Toilet Flange
Old 12-11-2003, 10:32 PM   #1
Unregistered
Guest
Unregistered's Avatar
Posts: n/a
Question
I have a question. I am remodeling a bathroom and didn't realize until I put the subfloor back down that the toilet flange is slightly crooked - it tilts slightly to the right if you were at ground level and looking at it from the front. I was wondering if I need to remove the subfloor and cut the drain and put a new elbow and flange in or if it is acceptable to use the flange as it is. Also, I will be laying tile and was wondering if the flange needs to be flush with the tile floor or if it is acceptable to be slightly below.
Help!
Old 12-13-2003, 09:59 AM   #2
Master Plumber
Tanias's Avatar
Re: Tilted Toilet Flange
Help!
It is best to have flange level and mounted flush on top of finished floor for a good seal between flange and commode bowl. The flange should be anchored through screw holes in flange. A bad seal can leak and ruin floor. Tanias
Tanias is offline
Toilet Challenge Vermaraj Plumbing 40 11-09-2007 09:04 PM
Toilet and the Flange troyamuso Kitchens & Baths 22 04-02-2007 01:50 AM
Toilet flange C.C.R. Plumbing 11 01-06-2007 02:48 PM
New help with this toilet flange Mike Finley Plumbing 2 06-16-2006 09:27 AM
Set-Rite - Toilet Flange Spacer System The Inspector Plumbing 24 10-13-2005 10:38 PM
