AbriamBarkerCarpentry
Three Inch Drain Pipe.
I'm putting a bathroom on the second floor of my house. It's a remodel job. Two years ago I remodeled my living room which is under the proposed bathroom, so I stuck a 3 inch PVC pipe in the 2x4 wall bay and sealed the room up with drywall.
Now my plumber wants to put a 4 inch drain in. Why isn't a 3 inch drain suffice? This is 3 inches interior diameter. I don't want to because my living room is in mint condition so furring out the wall would suck baaaaaad! |
FT.WORTH,TX MASTER PLUMB
Trade: plumbing
Re: Three Inch Drain Pipe.
Just using the info you provided a 3" stack will do fine.
YESTER DAY IS HISTORY, TOMORROW IS A MYSTERY http://paradiseplumbinganddrains.com...bers-dallas-tx |
Trade: hjrafiuoashfed
3" is fine, but pvc is not for a riser because:
1) Noisy. Imagine sitting downstairs and hearing the toilet water cascading down like a waterfall. Use cast iron to cut down the noise. 2) Fragile. The first picture that gets hung will be right where the pipe is and the picture hanget will be a 16p nail. Untold millions have been made replacing broken risers. Use cast iron. |
Trade: Plumbing & Gas Contractor
There's your three opinions.I concur,3" is fine.
Pro Plumber
Trade: Plumber
AS far as I know 3" pipe does not fit into a 2 x 3½" wall.
Re: Three Inch Drain Pipe. |
#9 | |
Pro Plumber
Trade: Plumber
Re: Three Inch Drain Pipe.Quote:
Add a hub fitting and now the OD is even bigger. |
#10 | |
The three inch pipe runs in the wall behind my 1st floor bathtub. From underneath in the basement the bottom of the 3 inch pipe is in the alcove of where the tub meets the wall. I have workable access from the basement. It will be a hassle but such is remodel work.
Trade: Plumbing
I put 3" pvc in 2x4 walls all the time. You have to cut the top & bottom plates all the way out but the od of the pipe is flush with the 2x4 wall. On an interior non bearing wall this is fine to cut the plates out.
Pro Plumber
Trade: Plumber
Yes it will be flush, just don't add a fitting in the wall or it will protrude out of the wall.
At the top of the 3 inch rise I needed a 3 inch T-Y fitting. My joist are 2x10's and there is no subfloor or bathroom partition walls yet. The only way I could think to get the T-Y fitting low enough was to cut the top plate out so the fitting slid down against the 4 5/8 inch crown molding that I have in the room uderneath.
Carpenters can make excellent plumbers... right? |
#15 | |
Hey, do you use that Stiletto hammer, too? |
Trade: plumbing heating gas fitting
you can run 3 full baths on a 3" stack, ofcourse 3" is plenty. if youre roughing a job does anybody put in cast iron, cost difference is huge. I have pvc in my walls and I dont here any cascading falls. why dont you do a side by side comparisan and see which produces more decibles, I'm sure the difference is not great. stick to service work..
The Grand Wazoo
You do that where I am you'll be tearing it back out.
#18 |
Pro Plumber
Trade: Plumber
#19 | |
| Drain Pipe | denick | Excavation & Site Work | 18 | 07-12-2009 04:41 PM |
| odd find for drain pipe | 72chevy4x4 | Plumbing | 9 | 11-06-2007 10:48 PM |
| black drain pipe?? | pauls painting | Plumbing | 5 | 01-08-2007 11:29 AM |
| Ace Duraflow vs PVC Drain Line Repiping to Replace Cast Iron Drain Pipe | TDELC | Plumbing | 0 | 10-16-2006 03:31 PM |
| How to rock around drain pipe that stick out 1/4in from stud? | ruskent | Drywall | 11 | 04-27-2006 12:02 AM |
