Trade: GC/Developer
Threads On Cast Cleanout Shot
I have a cleanout on the way to the street where the treads are shot. The pipe looks fine but it looks like someone tried to force a cap on a few years back and mangled the fitting's threads.
I cant cut the whole section of pipe out(easily) since it is a pipe that is a pit about 1'x2' and 2 1/2' down. There is no cutting it out without busting a good amoun of the garage floor out. How can I fix this cleanout? I would prefer a solution that would allow me to still use the cleanout down the road but will accept a solution that seals it out. There is a cleanout fairly close that I can get a snake into so a solution that closes it off would be okay. |
Pro Plumber
Trade: Plumber
Re: Threads On Cast Cleanout Shot
Take your question to diychatroom.com.
Trade: Plumber
Is it cast or PVC ?
If you get a reduceing bushing maybe you could get that in there even if you grinded the threads and used epoxy steel (if it is cast)to seal it in and got a plug for the smaller size Like 4X3 reduceing bushing you could still get the snake or whatever in the 3 inch Anyway thats my 2 cents |
Trade: Plumbing & HVAC, I specialize in Hydronic Heating and more specifically in Radiant Floor Heating
Your plumber will know what to do.
Otherwise take it to a DIY forum. This is a forum for plumbing professionals. |
Pro Plumber
Trade: Plumber
Since this is not a so called DIY question, and you have lots of post, then you can have a answer from a pro.
Buy a tap and re-tap the threads |
Trade: Plumbing
Re: Threads On Cast Cleanout Shot |
Pro Plumber
Trade: Plumber
If all else fails there is always silicone, is that what most DIY'er do.
| Flagging threads as "read" | Mark Twenhafel | Site Help and Suggestions | 14 | 11-17-2008 05:32 PM |
| best of threads | Z paint | Site Help and Suggestions | 1 | 01-31-2008 09:14 AM |
| Cutting cast iron in crawlspace | PacNWStructures | Plumbing | 31 | 01-25-2008 08:10 PM |
| Shot Blasting ????? | BulldogMedia | Sandblasting | 15 | 01-16-2008 02:14 PM |
| Cast Iron Pipe | denick | Excavation & Site Work | 18 | 05-13-2006 09:32 PM |
