copper magnet
![]() Trade: custom metal fabrication
Tempering Tank
My nat gas water heater is getting a little long in the tooth and I'm looking at replacement options.
Several years ago, I replaced my 50 y/o FAG furnace with a heat pump/gas hybrid and I'm well pleased with the performance and economy. Consequently, I've been interested in heat pump water heaters, but can't make the numbers work. So, I'm thinking of using a tempering tank which would take advantage of the heat pump supplied warm air in the winter to pre-heat the water before using gas to finish it off. Here's the question: Any reason not to use a cheap 50 gal WH as the tempering unit? I haven't found a tempering tank locally. |
| Clean out pancake compressor tank | bb71 | Tools & Equipment | 6 | 02-21-2010 02:51 PM |
| Buried 250 gallon propane tank | genecarp | Plumbing | 3 | 04-26-2009 07:30 AM |
| Septank Tank Separation Distance | Aggie67 | Plumbing | 3 | 04-20-2009 08:04 PM |
| Addition built on top of septic tank | KevinA | General Discussion | 20 | 04-02-2009 08:16 PM |
| Septic tank install help | metzade | Plumbing | 6 | 09-26-2008 09:47 PM |
