Temperature Rating Of Pipe
Old 07-29-2007, 10:16 AM   #1
Baltimore Electrician
JohnJ0906's Avatar
Trade: Electrician
Had something come up that made me curious. Had a recess can cause the circuit to trip, and when I removed it, I found that a small water leak had caused the termal protector to short. Directly above was the drain from a tub. There was 1 1/2" to 2" space between the can and the drain (PVC). The pipe felt bone-dry (dusty in fact) and it could very well be a caulking issue, not a plumbing issue. (The water amount had to have been very small, like 1/2 a teaspoon)
My question is this - Is there a temperature rating on plumbing PVC? Is there a distance that you would like to see from recess cans? Could the heat cause a leak? Personally, I would never have put this can where it was, but this was a service call.
John from Baltimore
"One Day at a Time"
All replies based on the 2008 NEC
Originally Posted by celtic
Deny Everything, Admit Nothing, Demand Proof
JohnJ0906 is offline
Old 07-29-2007, 04:11 PM   #2
Grumpyplumber's Avatar
Trade: Plumber
Re: Temperature Rating Of Pipe
Standard pvc is rated to operate at up to 140, but if you didn't see any perforation or burns on the pipe it's very unlikely that was the cause, if it's not touching I doubt it's a problem.
You could be right about it being a caulking problem or the overflow leaks when the tub is full, drain might have a leak at the shoe or in the trip waste tee.
Grumpyplumber is offline
Drain Pipe denick Excavation & Site Work 18 07-12-2009 04:41 PM
Condensation Help Patrick Windows, Siding and Doors 10 03-16-2007 09:40 AM
Gas Pipe Question.... drbigfresh Plumbing 9 02-28-2007 03:51 PM
Using Flex Pipe dirt diggler Pool Construction & Enclosures 8 02-25-2007 04:30 PM
How to trace gas pipe? karma_carpentry Carpentry 15 11-30-2005 11:47 AM
