Tankless Water Heater Freezing
Old 01-05-2010, 11:08 PM   #21
ARealplumber's Avatar
Trade: plumbing
Rewards Points: 75
Re: Tankless Water Heater Freezing
Originally Posted by KillerToiletSpider View Post
None of them.
I used to work for a shop that was an authorized Bosch repair company though.
Thats cool toiletspider because its news to me and i read alot atleast about the brand I use. I guess thats what the warranties for and rinnai has a good warannty. I'll install them if the money is right...I'm damn sure not in love with them.
ARealplumber is offline
Old 01-12-2010, 01:02 PM   #22
jeffreyplumber's Avatar
Trade: plumbing contractor
I saw an angry owner of a frozen bosh unit on you tube He was pretty Irate His was in the basement but it split the exchanger a couple times. Here in my neck of the woods freezing not an issue sunny and 70 so boring! But anyway how do you realy solve his problem? Bring it indoors?
jeffreyplumber is offline
Old 02-21-2010, 05:37 AM   #23
Plumbermurrieta's Avatar
Trade: Plumbing company
The tankless gas water heater has higher gas input ratings. The amount of gas used is related to the incoming water temperature and the volume of water moving through the heater. The burner modulates accordingly.
Plumbermurrieta is offline
Old 02-27-2018, 04:02 PM   #24
Sealik's Avatar
Rewards Points: 118
None of them.
Originally Posted by ARealplumber View Post
All you would need to do is have one faucet running to keep water moving through the water heater. This would be no different than a few dripping faucets added up. I've never heard that letting afaucet drip or run alittle with a tankless would foul the flow sensor. What manufacturer's users guide says this?
You'll foul up the flow sensor and send poor signals to the control panel, depending on the brand of tankless as to what gets screwed up from there, if it's a Bosch just write it off and start over again.
Actually...Eccotemp states to unplug (non antifreeze) units and open up a hot water tap (trickle) when temps drop. Flow sensors can actually detect a few drips coming out of a tap?
Sealik is offline
Old 02-27-2018, 06:35 PM   #25
flashheatingand's Avatar
Trade: H.v.a.c.
Rewards Points: 3,484
I would look into the possibility of an odt sensor that energize the water heater when temp gets to something like 37.... Somehow, somewhere, an efficient freeze protection setup?
That, or a recirc pump, keep the water moving periodically in the morning and evening? A double benefit.
http://www.37flash.com/
flashheatingand is offline
Old 02-27-2018, 06:40 PM   #26
Trade: H.v.a.c.
I like the idea of an outdoor unit. Here, for the most part, not necessary. But, that's "most" of the time. I would think by now there is an acceptable setup to account the other times.
Old 02-27-2018, 06:49 PM   #27
Trade: H.v.a.c.
Cool, there is a setup, and one could save $100.... $400 ? :0
https://www.amazon.com/Rinnai-104000.../dp/B006HE1THG
Supplying hot water to 4 apartments joesauers Plumbing Picture Post 8 03-30-2009 07:18 AM
Bosch tankless hot water freeze-up Doug161 Plumbing 7 01-14-2009 11:39 PM
Water Heater noises & air sputtering at faucets LarryS Plumbing 10 01-10-2009 09:41 PM
tankless water heaters plumberboy General Discussion 27 10-13-2008 06:14 PM
