07-20-2008, 01:01 PM
#1
Trade:
Remodeling
Tankless Heater Installation
Got a problem I need some help with. Customer wants to replace his old gas hot water heater with a new tankless one, probably Rannai, but I got a problem. He needs between 6-8 GPM for his two-story 4 bedroom home and to achieve that output we need a 3/4 inch gas supply. That wouldn’t be a problem I’d just run a new line but the existing HW heater is in his attic, it would take me a week just to run the line.
So, he and I thought why not put the new tankless heater in his crawl space, it’s about 5 feet in places. The gas meter is about 20 feet away so running a ¾ inch line is a breeze and just tie into the existing hot water line in at his kitchen sink. Then cap off his existing HW heater and gas supply in the attic. The hot water supply would essentially be reversing its flow. Anyone see any issues with this??
Thanks.
07-20-2008, 01:11 PM
#2
Trade:
Plumbing & HVAC, I specialize in Hydronic Heating and more specifically in Radiant Floor Heating
GET A PLUMBER WHO KNOWS WHAT HE IS DOING!
YOU HAVE NO BUSINESS DOING THIS JOB!
I hope anyone giving you technical advice is prepared to accept the liability his advice carries if you kill someone.
07-20-2008, 01:13 PM
#3
Plumber / Carpenter
Trade:
Virginia Building and plumbing contractor
I highly reccomend getting someone who is licensed and experienced. We just had a talk on another forum about an unlicensed handyman who caused the death of a child due to a gas explosion.
07-20-2008, 01:17 PM
#4
The Grand Wazoo
Trade:
Popcorn Vendor
If you can't spell Rinnai you probably have no business installing it.
07-20-2008, 01:38 PM
#5
Plumber / Carpenter
Trade:
good one, I did not spot that one KTS
07-20-2008, 02:01 PM
#6
Certified Remodeler
Trade:
Kitchen bath remodeler
If he strapped the heater to the meter, he could just run a power steering hose to the gas and water supply. A few clamps and your in business. But make sure you get a permit first and always have the work inspected. The clamps must be stainless steel of course or it won't pass inspection.
07-20-2008, 02:22 PM
#7
Pro Plumber
Trade:
Plumber
Those straps have to be copper plated or it will cause a corrosive build up.
Originally Posted by skyhook
Fact is I'm probably more qualified than 75% of the people on PZ, according to what I've read there.
07-20-2008, 02:29 PM
#8
Trade:
I thought they had to be lead coated.
07-20-2008, 02:31 PM
#9
Pro Plumber
Trade:
Plumber
They can be but you have to ground it 1st.
07-20-2008, 02:54 PM
#10
Trade:
I heard you have to ground it to the sewer. Is that true?
07-20-2008, 02:57 PM
#11
Pro Plumber
Trade:
Plumber
Yep use that green wire that you see in the trench.
07-20-2008, 03:25 PM
#12
Plumber / Carpenter
Trade:
man, have I been messing up. I been using the black wire to ground with!
07-20-2008, 03:29 PM
#13
Trade:
Plumber
I see two options for the fella.
1) Get a plumber and sleep at night knowing it was done legitimatly & insured.
2) Look around online until you can find a DIY site that might give the correct information from a total stranger (most plumbers won't freely oiffer this kind of advice), hope you did it right and try to ignore the fact that if anything goes wrong with it over the course of 7 years, the statute of limitations for a criminal act aren't up yet.
One small detail on the gas, venting or even the temperature could land you in court...with luck, it's only civil court.
07-20-2008, 03:30 PM
#14
Trade:
Plumber
HIRE AN ELECTRICIAN!
07-20-2008, 04:45 PM
#15
Service Plumber
Trade:
Plumber
Thought it was the red one?? Or maybe the blue?? Guess I should call the OP over to figure it out for me!
"To think for yourself you must question authority and learn how to put yourself in a state of vulnerable, open-mindedness; chaotic, confused, vulnerability to inform yourself. Think for yourself. Question authority". ..
07-21-2008, 06:01 PM
#16
Trade:
H.v.a.c.
I am not a plumber. I do HVAC work. The plumbers advise does seem valid, this stuff is not rocket science, but you need to know what you are doing (just like hvac, or electrical). Having said that, you can call the gas company and request a 1lb meter and install pressure regulators on all gas appliances. This will allow you to use the existing gas line.
But, read up on this. Because if you mess up, you could do a lot of damage.
07-21-2008, 06:07 PM
#17
Plumber / Carpenter
Trade:
an electrician? What, are you crazy? he is the one that started the water leak on the never ending story thread!
07-21-2008, 06:52 PM
#18
Trade:
Good grief! Don't tell this guy anything about gas systems like that. He HAS NO BUSINESS TOUCHING it. Period, end of sentence.
Besides, you have no business trying to give advice to begin with. A 1lb meter? What in thunder is that?
Look, I know you meant well. But we are trying to keep people from getting KILLED here. And you are hurting the cause.
PS. Yes, I know what you meant when you said a 1lb meter. Ain't no such thing however. First of all, they don't set the pressure at 1 pound. Second of all, it ain't the meter that controls the pressure.
07-21-2008, 07:14 PM
#19
Plumber / Carpenter
Trade:
darn, I was going to install mine that way
07-21-2008, 08:41 PM
#20
Service Plumber
Trade:
Plumber
 not rocket science? But yet a one pound meter and an exsiting line will do the trick  Its not science its just common sense. HIRE IT OUT!
| Thread Tools |
Search this Thread |
| Display Modes |
Rate This Thread |
Linear Mode
