Sweating Copper Pipes
Old 02-19-2004, 09:31 AM   #1
MikeF
Guest
MikeF's Avatar
Posts: n/a
Okay, maybe somebody here can settle this argument. I think we have too much time on our hands for this even to come up.
Regarding the flame on a torch used to heat copper pipes, which part of the flame is the hottest?
My friend swears that the closer you hold the pipe to the nozzle the hotter the flame is.
I on the other hand believe that farther out towards the tip of the flame is the hottest part. I guess that leaves the middle area open for someone else to prefer.
So which is it? The end of the flame, the middle, or close to the nozzle?
Old 02-19-2004, 05:38 PM   #2
General Contractor
hatchet's Avatar
Re: Sweating Copper Pipes
The hottest point of any flame is at the tip of the inner cone where it meets the deeper-colored outer flame. So I say it's the middle. This is for a typical propane torch - which I use for sweating pipes and soldering.
Rich
WIT Construction Co.
Superior MT Contractor
hatchet is offline
Old 03-03-2004, 12:28 PM   #3
Unregistered
Guest
Unregistered's Avatar
Posts: n/a
[hi mate just to let you know the hottest part of the flame is the tip of the inner flame hope this answers your argument
pipes sweating water carp 101 Plumbing 4 01-14-2007 01:06 PM
New Shower Pipes eager2start Plumbing 3 08-22-2006 05:49 PM
Painting new gal. gutters copper DeanV Painting & Finish Work 0 06-22-2006 09:39 PM
Copper vents -vs- plastic/aluminum shopman Roofing 2 03-01-2006 08:51 AM
Re-routing copper pipes in slab DRIFT-O-MATIC Construction 7 12-18-2005 04:36 PM
