Trade: plumber
Supply Tubes, Who Uses What?
I sometimes wonder if I am the only plumber left who still uses the chrome plated soft copper supply tubes.Sometimes, if it is a tight bend or a sloppy stub-out, I will use a braided or poly-supply.
So what do you use? |
Pro Plumber
Trade: Plumber
Re: Supply Tubes, Who Uses What?
Cutsom homes we always use crome or what ever the finish trim will be of, if they will be visible, if not visible we use poly supplies.
Plumber
Trade: Sewer Rat
I use ss/braided or poly
Moderator
Acorn headed chrome plated copper for exposed lavatories and toilets and Pex supplies for kitchen sinks and vanities.
If you get the right brand of chrome plated copper, you can just push your toilet supply washer, friction ring and supply nut up behind the acorn and slide the acorn up into the ballcock all the way. Once there, you can bend and align your supply tube and mark and cut flush to the top thread of your supply stop. Took longer to type this than to install. ![]() Install your stop nut and ferrule and pull the supply down into the stop, tighten that up, then tighten the ballcock nut up and you're set. No way that can ever blow out of the ballcock. BTW, have any of you ever cut up a SS over braid supply? The insides of them seem to be nothing more than flimsey surgical type tubing. They might be burst proof, but how many of you have ever had a toilet supply 'burst' on you?
Plumber
Trade: Plumbing
I never use poly, I only use chrome copper tube or ss braided , but custom work is always chrome copper tube.
AA, they tend to blow loose from the fittings anyway, pretty much the same as the reinforced plastic. I never did understand the loose woven SS, Tight woven, like Weatherhead, I understand.
contractor
Trade: carpentry plumbing electric
I like to flare my copper tube above the cone washer.Had a toilet supply blow out once,shortly after I left the job.It was my fault,I know.tube did not extend far enough.After my embaresment,I vowed to never let it happen again.
Trade: Commercial Roofing Inspector/ Trainer
SS Braided
Trade: Renovations
ss braided
Trade: plumbing
braided
Trade: plumber
call me stubborn or old school, but I can't seem to trust the braids not to burst and flood a house. Any horror stories out there involving braid bursts?
#13 | |
Trade: plumbing
Re: Supply Tubes, Who Uses What?Quote:
I used to use nothing but pex supplies due to cost and the speed with which they can be installed (holdover thinking from my new construction days) but within the last 6 months I have gone back to chrome plated copper. A friend of mine, whom I once worked for, told me a horror story one day about a pex supply they had installed that blew out of the angle stop under a ks and did a lot of damage. I kept using them thinking someone must have just messed up and didnt install it properly. A few months after that I went to a service call for a lav supply that had been flooding. At first glace it looked like a jackleg install in which the pex supply had been cut too short and had just pulled out of the angle stop. The supply at this point barely reached the top of the nut. When I went to insert the new supply into the angle stop it would'nt go. I shined my flash light into the angle stop and discovered that the previous supply had not been too short it had simply broken off just above the compression nut. It took about 10 minutes to dig out the remains of the old supply. That was when I made the decision to go back to chrome plated copper. It won't blow out and if it leaks it will only be a drip at one of the nuts. I guess no burst with metal nuts only might be ok but it is still only a rubber hose inside a mesh sheath and plus I decided that it is better for me and my family and my company if my customers call me for ALL their plumbing needs. No burst flex lines might make some people think "Hmmm, no special tools or knowledge required here, I think I can do this." |
Trade: plumbing
Oh yeah, I spent $10 or however much it was on a cheapy set of tubing benders because it is often very hard to get the right bend in a toilet supply without mangling it. One of the best tool purchases I ever made! It makes it so much easier and faster and I haven't had to throw away a single supply because I kinked it since.
Pro Plumber
Trade: Plumber
We use thousands of pex supplies, the thing about it is you can't use brass ferrule that come with the angle stops, you have to use the poly plastic ferrules.
Using the brass ferrule will cut the supply with no hesitations. |
Trade: plumbing
Yes! When I was using them I always used the plastic ferrules, but the one I came across that was broken (and it was broken not cut) also had a plastic ferrule. I too have used many, many pex supplies and to my knowledge have never had a problem. I just decided I did'nt want to take the chance anymore. It's not a big deal really, it adds about $3 to the cost of the install and adds less than 5 min. each to the install all of which is passed on to the customer. It is also generally pretty easy for the customer to see the value of it which makes them appreciate me more for installing top quality instead of that "other plumber" who would cheap out on them and open the door to some level of unnecessary risk so that he could save $3 on materials. I'm not knocking anyone who uses pex supplies I'm just trying to generate additional customer appreciation and loyalty by educating them about the benefits of the higher quality of the product I am installing. Mostly though they could care less but I don't ever have to worry about it after I leave it.
Somebody sell me on PE other than cost. I've had a host of falures with the stuff.
#18 |
Pro Plumber
Trade: Plumber
Re: Supply Tubes, Who Uses What? |
#19 |
contractor
three years is not good enough for me.what is 50 ( or maybe 25 ) years going to cost.In other words , what does history tell us .considering history ,tell me what is better than good copper supply tube.In 25 years if pex is still holding up ,I will be sold.
| drywall supply place in Central PA | fr8train | Drywall | 10 | 01-31-2008 09:27 PM |
| The reflective sheets you find in solar tubes? | metomeya | Construction | 13 | 12-01-2006 01:39 AM |
| Colorado Contractors - Home Depot Supply 50% off | Mike Finley | General Discussion | 20 | 12-23-2005 10:57 AM |
| Flushmount Light with MIN 90C Supply Conductors | kpikul | Electrical | 1 | 11-15-2005 06:41 PM |
