Sump Systems That Mount Above Grade?
Old 01-16-2008, 01:49 PM   #1
wackman's Avatar
Trade: Builder, Additions, large remodels...Lately also small remodels.......
I've got a peculiar situation with one house where someone has dug down the basement to get more head height. This has caused the cast iron to be above the floor grade. We're in there now completely redoing the foundation/slab and we need to figure out the sump system. I've never had to do one of these, all the baths we've put in basements the cast was always sub grade.
So one of my plumbers is recommending the traditional sump pit and motor in a closet. This causes a problem with the intended layout of the basement and he is very unfamiliar with the other suggestion.
The other plumber is recommending a saniflo system where the sump pit mounts to the back of the toilet under the tank and has inlets for the shower and lav to tie in. Then it uses a macerator (basically a garbage disposal) to chew it all up, even feminine products, and expels it through a 3/4" line. This system would give us much more flexibility with the layout and be simpler than the normal way, if it works as advertised. All my suppliers sell thos product and they say fine things about it but seem a bit unfamiliar with it.
Any experience with this system? Pros? Cons? Any recommendations would be great.
Thanks,
Wack
wackman is offline
Old 01-16-2008, 02:59 PM   #2
Re: Sump Systems That Mount Above Grade?
Sure will be listening in on this one!
Personally I don't believe in the
Tooth Fairy, and I've never believed
in that ¾" line stuff either.
Hope some one here has been up close
and personal.
neolitic is offline
Old 01-16-2008, 05:43 PM   #3
The Grand Wazoo
KillerToiletSpider's Avatar
Someone is trying to set himself up with a lifetime of service work fixing this horrible mistake.
KillerToiletSpider is offline
Old 01-16-2008, 05:57 PM   #4
TimelessQuality's Avatar
Trade: GC/Remodeling
Wow that's a coincidence...I looked at that same basement today hehehe...
The HO was thinking macerator toilet. I was thinking cut into existing sump pit and change to a sewage pump. I've looked around a little, and most say they need 18" D pit. How critical is that?
-Steve
"The most beautiful thing we can experience is the mysterious. It is the source of all true art and science." ~ Albert Einstein
TimelessQuality is online now
Old 01-16-2008, 06:01 PM   #5
Putty Truck's Avatar
Trade: hjrafiuoashfed
I love complicated systems...they make me money, but to make life easy do the following.
Redo the drain and sewer:
Get a camera/locator with depth finder first to figure out if it is possible.
Bury the house drain under the new slab accirding to local codes. You will have to replace the outside sewer, at least to the point where grade normalizes. Most sewers nose-dive at the property line, so be prepared to go that far. You may get lucky and it will go deep right outside the house.
Don't forget clean-outs outside.
Putty Truck is offline
Old 01-16-2008, 08:01 PM   #6
wackman's Avatar
Boy, are sump systems that bad? I can get the sump done for around $800. To completely redo the line out to the street would be more like $3k. I have a hard time believing I'm going to be coming back for warranty work on a sump pump to the tune of $2200.
The city made us redo the entire foundation so now there's a 18" deep X 36" wide "L" shaped footing on the inside of the existing unreinforced brick foundation. Tons of bar in it too. It'd be a lot of work to go through or under that now, where as the sump pit can just be dug in the field before the slab.
wackman is offline
Old 01-16-2008, 08:13 PM   #7
masterk's Avatar
Trade: Plumbing
Put a liberty or meyers sewage injector pump and pit package in. The discharge is 2". The system you are talking about I've seen alot of problems with and I won't install them.
masterk is offline
Old 01-16-2008, 08:26 PM   #8
Job killer.
Old 01-16-2008, 08:38 PM   #9
wackman's Avatar
Job killer.
Tell me about it. 3 meetings with them before I bought it asking what they'd require to be done and none said a word about all this.
"I only bother remembering things that I can't easily look up." Albert Einstein
wackman is offline
Sump Pump runs often robertc65 Plumbing 13 03-23-2010 08:49 PM
Running basement walkout drain into sump robertc65 Plumbing 18 05-05-2008 08:26 PM
Seperately-derived systems Mark Twenhafel NEC Discussion 3 11-11-2007 10:18 AM
New Photovoltaic Systems Textbook Magnettica Electrical 0 08-19-2007 10:44 AM
Mixing mortar with sump pump water mdshunk Masonry 13 01-25-2006 04:58 PM
