Sump Pump Output
Old 01-17-2010, 08:38 AM   #1
mpt1123's Avatar
Sump Pump Output
Guys:
Not sure if this is a plumbing or a landscaping question, but I'll start here. Sump pump output port is at the top of a slope. The water runs down the slope, into the french drain, and back into the sump pump. Sump pump runs constantly when it rains. The water causes a runoff trench in the homeowners landscaping which he'd like to correct. We'd like to trench out from the house and redirect the water into the yard. I'm hesitatnt to connect some PVC piping to the sump pump outlet for feat that any clogs in the pipe could cause a sump pump backup. We were also thinking about placing a small catch basin below the sump pump outlet and redirecting the water from there. Are we overengineering this design? Should we just attach the PVC and be done with it?
Thanks.
mpt1123 is offline
Old 01-17-2010, 11:09 AM   #2
Capra aegagrus
Tinstaafl's Avatar
Re: Sump Pump Output
Why would the pipe clog? You're not pumping solids through it, are you? All else being equal, I'd think pump failure would be more likely over time than a clog.
You could always just put a couple of cleanouts in that could be left open in an emergency.
Tinstaafl is offline
Old 01-17-2010, 03:48 PM   #3
mpt1123's Avatar
Since it will drain onto the lawn I'm worried that critter will get up there, some muclh, etc. that would clog it. I don't want to solve a small problem and then cause a flooded basement.
Thanks.
mpt1123 is offline
Old 01-17-2010, 04:24 PM   #4
tgeb's Avatar
I would run a 4" drain pipe.
But instead of "tying it in" to the sump line, I would leave an air gap, so that if the drain line clogged the water would simply run out on the surface.
Does that make sense?
www.gebcon.com
tgeb is offline
Old 01-18-2010, 10:04 AM   #5
mpt1123's Avatar
Sorry. I'm only familiar with air gaps installed in dishwasher drain lines. If you mean mean an actual 'air gap', then I think we're back to the catch basin idea. Small basin to catch the water from the sump pump, which is then redirected to the lawn. Worse that can happen is the catch basin and/or 4" line clog up and the sump pump spills out where it is today.
mpt1123 is offline
Old 01-18-2010, 05:57 PM   #6
tgeb's Avatar
Well I can't see your actual circumstance but let's say for instance:
You have a sump line 1-1/2" that exits the foundation wall and turns 90 degree down, put your 4" drain pipe with a 90 degree turned up below the pump outlet and direct the the flow of the smaller pipe into it.
This would be less likely to clog with debris than would a basin with a grate.
www.gebcon.com
tgeb is offline
Old 01-19-2010, 06:25 AM   #7
mpt1123's Avatar
Got it. Thanks.
mpt1123 is offline
Sump Pump runs often robertc65 Plumbing 13 03-23-2010 08:49 PM
Sump pump system ARTSBEST Plumbing 5 05-17-2009 12:20 PM
Sump Pump - Burying the Line Deeper - How Deep? AboveAndBeyond Remodeling 4 02-11-2009 12:22 PM
Exterior grade sump pump? Jeeper1970 Plumbing 1 12-27-2008 10:16 AM
Sump Pump questions WhitlockConst Plumbing 3 08-17-2008 12:32 PM
