Sump Pump Knocking
Old 04-27-2011, 10:39 PM   #1
sbcontracting's Avatar
Trade: General Contracting
Rewards Points: 562
Sump Pump Knocking
Hey there.
Just installed a sump pump... well my plumber did actually. HO told me over the weekend that it was knocking. They have a bedroom right above.
Plumber explained to me that it was the pump stopping. It just shuts off, causes a wave in the outgoing water line, back and forth, etc..
But this was some crazy banging. I even held the pipe tight, to simulate a good fastening job and the thing was loud. Is this normal? The plumber's boss thought it might have been a failing check valve (he didnt see it)... The runout is about 25' 1-1/4" abs.
Are there solutions? Does a hammer arrest work in this situation?
Regards, Mike.
Ottawa General Contractor
http://www.springer-boyd.com
sbcontracting is offline
Old 04-27-2011, 10:48 PM   #2
Mike's Plumbing's Avatar
Trade: ooo
Rewards Points: 2,000
Re: Sump Pump Knocking
Well, one thing that makes a big difference is the type of pump and the type of float. A pump that has a high GPM rate combined with the right float can really make noise.
If possible go buy some armaflex and a 3" J-Hook to support it. It will act as an anti vibration support. Just a small piece wrapped around where the J-Hook goes can really make a difference.
Mike
see ya!
Mike's Plumbing is offline
Old 04-28-2011, 10:41 AM   #3
Carbon Dioxide Producer
DuMass's Avatar
Trade: EC
I have a Flotech pump in the laundry tray under the slop sink in my basement that has a inline check valve at the base of the pump and it will make a noticeable clunk when it closes after pump out, but I only hear it when I’m in the area of the slop sink and wouldn’t really consider it to be abnormally loud.
Maybe the sound from the check valve is telephoning up the pipe in your situation. Did the plumber install a banded no-hub coupling on the drain line at the pump? If so, I’m wondering if maybe installing another regular rubber Fernco coupling on the drain line, in the non-pressurized part further downstream, might help isolate the noise.
DuMass is offline
Old 04-28-2011, 11:59 AM   #4
The Grand Wazoo
KillerToiletSpider's Avatar
Rewards Points: 1,864
Change the piping so that the check is on a 45 degree angle, it will reduce the closing noise.
KillerToiletSpider is offline
Old 04-28-2011, 08:32 PM   #5
plumber4200's Avatar
Trade: Plumbing
Smile
SB,
I think it also may depend on the type of check valve, but all of them I have installed (100's) have mad that banging sound. How high is the vertical head on the pipe? Seems to me the loudest ones are always the ones with the most vertical rise before going horizontal. Just food for thought.
Patrick
plumber4200 is offline
Old 04-28-2011, 09:10 PM   #6
Rewards Points: 562
This noise is a little unusual - It's about 15 bangs, it takes about 10 seconds to stop banging. I think it is anyway.
It goes up 8 foot, then horizontal 25 foot. I'll see if I can get him to get the check valve on a 45, and put another fernco in there.
I'll just have to figure out how to provide this advice: "I was online and this plumber said I should..."
... nah, I'll go with one that always works:
"I was watching this episode of Holmes on Homes and..."
Thanks folks!
Mike
Old 04-28-2011, 10:36 PM   #7
Trade: ooo
Hey, before you get to cared away here you better make sure the outlet isn't plugged or partially blocked. If it's that bad it sounds like pressure is building because of resistance.
One more thing to check is the float. Look and see if it hung up. Sometimes pulsating in the pipe can be caused from a bad float or a float that takes it's time shutting off.
Sounds like an interesting problem, let us know what you find.
Mike
see ya!
Old 05-07-2011, 07:14 AM   #8
422 plumber's Avatar
Trade: industrial plumber
Rewards Points: 25
put in a "quietcheck"
422 plumber is offline
Old 05-08-2011, 08:48 PM   #9
Rewards Points: 562
They changed the check valve, has a hammer arrest built into it. Seems to have done the trick.
7000gph Sump Pump in Backyard PAcontract Plumbing 10 04-01-2010 04:56 PM
Sump Pump output mpt1123 Plumbing 6 01-19-2010 05:25 AM
Sump pump system ARTSBEST Plumbing 5 05-17-2009 11:20 AM
Sump Pump - Burying the Line Deeper - How Deep? AboveAndBeyond Remodeling 4 02-11-2009 11:22 AM
Exterior grade sump pump? Jeeper1970 Plumbing 1 12-27-2008 09:16 AM
