Submersible 2-wire Well Problem
Old 01-17-2004, 12:01 AM   #1
Unregistered
Guest
Unregistered's Avatar
Posts: n/a
Just moving into a different house, a couple weeks ago apparently a pipe broke and water ran for a very long time inside the house. Today I found the house plumbing was winterized so I wanted to de-winterize it so I can start working inside. Now, after turning on well pump breaker, no water! Bought as is, so the question is this. Could the pump have heated and siezed up when it was running for so long? Could the line be frozen at the pitless adapter or elsewhere outside (It's been anywhere from 0 - 20 degrees for days now)? How can I check this to see if it is froze? I am very mechanical and so far have determined that everything inside the house is working such as the pressure switch....also has power to the two wires leaving the house. I'm just lost as to my next step. Would I feel or hear that the pump was running from the line going to the tank in the basement? Tomorrow I will try to find the well casing in the yard....too dark now and I was freezing out there. Thanks for any advice!!
Old 01-19-2004, 06:24 AM   #2
Bjd's Avatar
Re: Submersible 2-wire Well Problem
Try using an amprobe to see if the pums drawing any amps, at least that will let you know whats going on down there.
bjd
Bjd is offline
Ventilation problem with an indoor pool frostbitten1 Roofing 10 05-27-2009 09:16 PM
Wire balustrades karma_carpentry Decks & Fencing 11 09-17-2007 06:10 PM
Another aluminum wiring question ron schenker Electrical 18 03-08-2007 06:54 PM
Well problem paintr56 Plumbing 10 02-09-2007 09:20 AM
safe hot wire driver Electrical 13 05-12-2006 11:18 PM
