Stud Reinforcement?
Old 11-05-2017, 05:22 PM   #1
Blizzol's Avatar
Trade: Gc
Stud Reinforcement?
Working on a bathroom where the plumbing and vent needed to be rerouted. Top and bottom plates had holes put in them more than 50% as well as two 2x4 studs. House is built on floor trusses so all load is on outside walls. Will stud shoes be enough structural support on this. Pic attached.
Stud reinforcement?-img_20171105_120921109_burst000_cover_top_1509924097606.jpg   Stud reinforcement?-img_20171105_120932592_1509924126630.jpg
Blizzol is offline
Old 11-05-2017, 06:47 PM   #2
slowsol's Avatar
Rewards Points: 2,212
Re: Stud Reinforcement?
Do you know that for a fact, or are you assuming that? Some floor trusses have mid point bearing.
-John
slowsol is offline
Old 11-05-2017, 06:49 PM   #3
Blizzol's Avatar
Trade: Gc
Yes, we took down a couple of interior walls the level below so had it all looked at.
Blizzol is offline
Old 11-05-2017, 07:31 PM   #4
NJGC's Avatar
Location: Unfortunately I live in the communist republic of NJ.
Rewards Points: 78
If that's just a partition wall, who gives a chit?!
Sent from my SAMSUNG-SM-G930A using Tapatalk
NJGC is offline
Old 11-05-2017, 08:02 PM   #5
Blizzol's Avatar
Trade: Gc
Sorry for the confusion, the wall in question is the exterior wall which is carrying the load.
Blizzol is offline
Old 11-05-2017, 10:47 PM   #6
GC/carpenter
Californiadecks's Avatar
Rewards Points: 6,960
While I understand a stud shoe isn't supposed to take the place of total removal of material, could you add two or three more studs with shoes maybe even a 4x to make up for it?
Mike.
_______________
Californiadecks is offline
Old 11-05-2017, 10:48 PM   #7
GC/carpenter
Or fur the whole wall out?
Make it a 2x6 wall? Lots of options there.
Mike.
_______________
Old 11-06-2017, 07:25 AM   #8
hdavis's Avatar
Rewards Points: 8,017
No.
hdavis is offline
Old 11-06-2017, 08:47 AM   #9
hdavis's Avatar
You can have a solution engineered. The result is going to look like a pair of Simpson TPA 39 with a cut out so it will slide in place. The flanges are flushed to the stud when you install, so you don't wind up with a bump in your wall.
Note tpa39s aren't code approved for compressive use. Also note they are heavier gage than a stud shoe, and have way more nails. Nailing pattern is a tip off for structural repairs. If a stud shoe was tested, 4 nails might get it 200 lbs load before you start getting nail withdrawal.
hdavis is offline
Old 11-06-2017, 09:58 AM   #10
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Builder/GC
Rewards Points: 90
Mike.
_______________
Yup. That's my favorite.
And this, ladies and gentleman framers, is why we build a little something called a "wet wall". Even if the exterior is 2x4 construction, the bathroom can be 2x6.
I would reframe with 2x6's, and then reroute the plumbing. Personally.
Delta
I have an Edifice Complex.
Californiadecks (11-06-2017)
Old 11-06-2017, 10:01 AM   #11
Trade: Builder/GC
Rewards Points: 90
Oh, and put some blocking in there for the towel holder, butt-wipe holder, grab bars, etc.
And it might be easier to just strip that wall of drywall. Wallboard is dirt cheap, and it's a lot easier and quicker than trying to do a ton of odd-ball patches.
Delta
Old 11-06-2017, 08:31 PM   #12
tjbnwi's Avatar
Rewards Points: 2,894
Guess wrong and this may be the results.
Stud reinforcement?-img_3268.jpg   Stud reinforcement?-img_3270.jpg   Stud reinforcement?-img_3274.jpg   Stud reinforcement?-img_3276.jpg
tjbnwi is online now
Old 11-06-2017, 09:50 PM   #13
hdavis's Avatar
Just order the engineered ones and there is no guess work.
hdavis is offline
Old 11-07-2017, 12:48 AM   #14
cedarboarder's Avatar
Trade: Workaholic
Rewards Points: 872
Mike.
_______________
Yup, only way unless some engineer signs off on some band-aid. 2x6 where the plumbing is and fur out the rest. rerun the plumping with a drill, not a sawsall
cedarboarder is offline
Deadbolt strike reinforcement plate vs. frame reinforcement plate? tipitop General Discussion 58 07-22-2015 11:06 AM
Construction Master, Rake Wall so1storm Framing 0 07-22-2014 12:57 PM
consequences of improper steel stud drop ceiling installation mohdmaruf Drywall 29 04-02-2013 11:43 PM
Recommendations needed for wall stud scanner... svronthmve Tools & Equipment 6 09-28-2012 04:06 PM
2x4 Basement Stud Walls On a Three Story Home WITH NO FOOTER Baltimore Carpentry 13 08-16-2012 07:02 PM
