Strange Leak During Harvey
Old 09-07-2017, 09:46 PM   #1
AJMCC's Avatar
Trade: Remodel/Build
Rewards Points: 2
So i have a customer who i have done work for before...
During hurricane harvey their water got shut off for about 5-6 hrs or so. When the water got turned back on, they went to use a bathroom only to find water pooled up inside the vanity and had spilled all over the floor.
i stopped by today to check it out and locate the leak but everything is dry and looking fine. I ran the sink faucet both hot/cold and the valves/drain/supply lines are normal.
Could the water being shut off for that long built up a high pressure that when turned on it caused a temporary leak? Or am i missing something here
AJMCC is offline
Old 09-07-2017, 10:17 PM   #2
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
Re: Strange Leak During Harvey
could the plumbing vent have leaked thru the roof in the rain?
Tom Struble is offline
The Following 2 Users Say Thank You to Tom Struble For This Useful Post:
Fouthgeneration (10-04-2017), Rio (09-08-2017)
Old 09-07-2017, 10:46 PM   #3
WBailey1041's Avatar
Trade: Gutters
Rewards Points: 1,401
Or the exhaust vent for the fart fan?
Welcome to the forum.
WBailey1041 is offline
The Following User Says Thank You to WBailey1041 For This Useful Post:
Rio (09-08-2017)
Old 09-08-2017, 09:42 AM   #4
VinylHanger's Avatar
Rewards Points: 7,596
Probably just one of those once every 100 year leaks.
VinylHanger is online now
Old 09-25-2017, 03:42 PM   #5
PlumbingGuy13's Avatar
Trade: Plumbing
Rewards Points: 8
I wonder if this has happened more because of all the rain. I'm up in Kansas City and they've had some flood weeks about a month ago and I saw some weird leaks too. I'm guessing its because of the high pressure from the amount of water.
PlumbingGuy13 is offline
Old 09-25-2017, 04:45 PM   #6
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 96
Water backed up through the plumbing?
SLSTech is offline
Old 10-04-2017, 12:01 AM   #7
jacki's Avatar
Trade: PLUMBING
I also have a similar ‘water pressure build up’ issue. The water comes rushing out about twice the normal pressure when I turn on any faucet in my home. It will last only for 2-3 seconds and then drop back to normal pressure in most cases. Sometimes, the pressure will not come down until I turn off the faucet and then turn it back on. The pressure seems to build up only when the water hasn’t been used for a while. I am quite concerned about this issue. I tried turning the screw on the top of my pressure regulator to down the pressure, but the water still comes out way too high when the faucets are first turned on. For the time being, I have decided to seek the help of a plumbing service in Markham to fix this. But I want to know whether is there anything I can do myself to fix this. Any help will be appreciated. Thanks in advance.
jacki is offline
Old 10-04-2017, 07:00 PM   #8
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 6,347
Jacki: Most likely you need an expansion tank on your Hot water heater, the installation of back flow preventers on residential homes stops the expanded hot water from "backing" up into the city mains, thus when your cold water is heated, the expanded water creates added pressure.
till then turn the temp down on the Hot water heater.
Registered as a plumber, but didn't want to spend money on a DIY? Hmmmm?
What would Sherlock Holmes say TINSTAFL?
The OP : maybe the massive drop in air pressure Burpped his DWV lines?
Last edited by Fouthgeneration; 10-04-2017 at 07:04 PM. Reason: spelling and DIY alert
Fouthgeneration is offline
Old 10-04-2017, 08:16 PM   #9
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 2,059
Dunno. Holmes' time predated SEO.
Tinstaafl is online now
Old 10-05-2017, 01:59 AM   #10
Trade: Masonry
Tin, it appears to me Jackie is a Toilet wholesaler/distributor employee, who actually knows very little regarding actual plumbing, her claimed area of skill.....
but I am not the gatekeeper here.
Regards to the OP, strange things can happen as input pressures drop on pressure regulators and hydraulic systems are isolated. I'd suggest a high quality pressure regulator in addition to a oversized expansion tank, and of course anti-hammer devices at the end of long straight piping runs.
Need help finding a leak! Gary L Roofing 12 01-14-2014 03:28 PM
Finding a middle ground on a strange job. NYCB Business 6 11-09-2012 07:28 AM
Strange smell from old plank subfloors bob_cntrctr Flooring 9 09-09-2012 06:49 PM
Strange shower leak - need help JSMHDM Plumbing 13 12-06-2010 04:38 AM
Refrigerant Leak Detection Articles MechAcc HVAC 7 10-09-2009 04:42 AM
