Strange Fly Problem
Old 06-09-2006, 09:31 PM   #1
johnnymac's Avatar
Trade: plumbing
Strange Fly Problem
I hope I can explain this right....
We received a call the other day here in South GA. the client said that he had a problem that we might be interested in. He had another plumber come out to the house and try and fix the problem 3 or 4 times but no luck.
He lives in the country and has blowflies(?) (the man called them $h@tt flies) in his bathroom but no where else in the house. He has a septic tank system.
My son went over there and after crawling under the house he found three vents, two were not capped and no longer needed so he capped them off. The last one on the toilet wasn't tied in, going out to the roof, so he tied that in. Flies still coming back.
2nd time..He went back out there, cut the vent loose and capped it off. He put a studder (sp?) vent on the toilet, capped the vent on the roof and left.
Five days later, the man calls again, flies are back.
The only things on this sytem are two toilets and both going into the septic tank, of course.
When my son cut the vent loose, he saw a couple of flies in the pipe, but can't figure out how the flies are in the pipe and on the bathroom ceiling.
Has anyone come across this type of problem? The client said that this has been going on for a couple of months or longer now.
Thanks,
Melody
A Plumber's wife
and mom of two Plumbers
johnnymac is offline
Old 06-09-2006, 10:20 PM   #2
Teetorbilt's Avatar
Re: Strange Fly Problem
What does the fly look like? The typical 'outhouse' fly is about 1/4" long and has delta wings when at rest. This indicates a sewage leak somewhere. Bigger flies mean many other things.
Albert Einstein
Teetorbilt is offline
Old 06-10-2006, 07:40 AM   #3
Plumber
tzzzz216's Avatar
Trade: Plumbing
It also sounds like something may have died under the house maybe a small animal, but then you would be getting a foul odor,let us know what you find.
tzzzz216 is offline
Old 09-06-2006, 11:41 PM   #4
contractor
cmwacasey's Avatar
Trade: carpentry plumbing electric
you may need to hire a carpenter.plumbers are notorious for cutting their access holes to large.
cmwacasey is offline
Old 09-07-2006, 02:30 PM   #5
Plumbing/Mechanical Insp.
Moscow's Avatar
Trade: plumbing/mechanical/building inspector
I have seen this in crawl spaces were the sewer line has been broken or damaged. We called the health department in on one and they said they are called sewer fly's and if you get rid of the open sewer or open vent and kill the fly's with a chem bomb and replace the vaper barier they should go away. We advised the customer of this they did it and 5 years later still no fly's.
Good Luck
Justin
Moscow is offline
Ventilation problem with an indoor pool frostbitten1 Roofing 10 05-27-2009 09:16 PM
Bathroom Paint Problem - Strange Peeling firemike Painting & Finish Work 23 09-27-2007 07:53 PM
Well problem paintr56 Plumbing 10 02-09-2007 09:20 AM
Strange toilet problem Rich Turley Plumbing 11 01-13-2006 08:09 PM
Electrical problem? Brian Electrical 5 12-27-2005 11:16 AM
