Plumber
Trade: Plumbing
Stoppage , In Space Saver W.C
Can anyone tell me if they had any problems with the American Standard space Saver W.C ? I installed 2 of these in the same house about a week ago ,1 in the masterbath and 1 in the guest bathroom , the Ho kids us the guest bath ages 17 & 14 , , They called me out 3 days ago and said the guest w.c. is backing up i went over and plunged and augered out and it was cleared and then put the test to it with toilet paper about 4 or 5 times never backed up on me ,so today they called me again and said it was backing up ,i checked all the clean outs and everything was dry, then i went in inside and check out the w.c and sure enough it was backed up but as i was watching it it emptyed out , then i pulled the w.c to see if the riser was full of water it was bone dry, while i had the w.c off i ran my cable down the line 30' the line was clear !! I took the toilet out side and turned it over only to find the trap packed with doo nothing else in it . So my question is this are those kids dumping big time -----s , to much TP or is it the maybe 1'3/4 trap way causing it or the new water closet , the master bathroom is working great per HO same brand in their installed the same day . Thanks in advance .
Trade: general contractor - SFR
Re: Stoppage , In Space Saver W.C
I use these space savers and have never had any problems. A logical step: swap the toilets with each other and see if the problem persists at the same hole or follows the toilet. Voila - problem isolated.
"How much per sq.ft? Well.. gimme $1K and I can build a shed. Gimme $1M and I can build the same size shed with gold plating and encrusted diamonds." |
Pro Plumber
Trade: Plumber
Sounds like kids are overloading the toilet to me.
Plumber
Trade: Plumbing
Re: Stoppage , In Space Saver W.C |
Trade: Plumbing Contractor
I too was having a problem with a new American Standard space saver the other day. The home owner installed it a few weeks prior, i plunged it and augered it, and it would flush fine, and about every for or five flushes, it wouldnt flush.
#6 | |
Plumber
Trade: Plumbing
Re: Stoppage , In Space Saver W.CQuote:
#7 | |
Trade: Plumbing
| hole into garage space for refrigerator | markoni | Remodeling | 5 | 05-09-2007 12:23 PM |
| space above crown | ch0mpie | Finish Carpentry | 6 | 03-06-2007 01:41 AM |
| crawl space insulating | letgo | Carpentry | 13 | 12-16-2006 03:33 PM |
| Crawl Space Ventallation? | Good Stuff | General Discussion | 0 | 12-04-2006 05:15 PM |
