Stoping Rain Leak Issues On Vent Stack With 2 90's?
Old 03-05-2009, 11:19 PM   #1
The Security Guy...
Security101's Avatar
Trade: "Alarm Company" CCTV PERS GPS 24Hr LV AV
Hey folks,
I have two 3" vent pipes on our house that apparently the original homeowner (GC) decided he didn't need to use adhesive to secure his drain work (we have replaced most of the interior drain and vent pipe after years of leaks for previous owners)
Here's the issue, these pipes are in the exterior wall and just so happen to be located behind an intersection of an interior wall, and will involve some serious re construction to access, and we aren't prepared to do that - at this time.
Here's the question, can I install two 90's on the top of the vent to basically have the "rain hole" pointing down instead of up? Will this cause any problems with venting? It doesn't seem like it would...
Until we can get into it, we would like to stop the leaks and carpenter ants (we know the damage we'll need to repair is extensive by the examination from down below)
Thanks
Jim
"Rest Assured - You're Secured"
Security101 is offline
Old 03-05-2009, 11:30 PM   #2
the pipe master
protechplumbing's Avatar
Trade: plumbing, solar
Re: Stoping Rain Leak Issues On Vent Stack With 2 90's?
Mechanically, no problem.
Esthetically, sanford and son.
It would also make snaking and/or jetting interesting if that was ever needed. The verdict, hackery.
Plumber, Repiping, Replumbing, Leak Detection, Solar Water Heater, Polk County Plumber, Lakeland Plumber, Winter Haven Plumber
protechplumbing is offline
The Following User Says Thank You to protechplumbing For This Useful Post:
plumbworker (03-05-2009)
Old 03-05-2009, 11:35 PM   #3
The Security Guy...
I can appreciate that ...
I would just probably press fit them anyway (for your noted reasons) - why not - none of the old stuff's glued
But seriously, I would glue the nipple to the 90's but leave the joint to the vent dry (would still keep the H2O out but would be removable if needed)
Jim
Old 03-05-2009, 11:59 PM   #4
the pipe master
I see no major issues with that as long as it truly is temporary.
Old 03-06-2009, 12:21 AM   #5
DRIFTWOOD
Driftwood's Avatar
Trade: GEN CONTR.
Vents can't return down !
Driftwood is offline
Old 03-06-2009, 12:35 AM   #6
The Security Guy...
That was one of my other concerns, do you happen to know what the issue is with that? thanks...
Are there any covers that are acceptable or some other approved method to just deflect rain/snow?
Even though they would be temporary, don't want any issues either!
Jim
Old 03-06-2009, 07:05 AM   #7
the pipe master
That why I said TEMP is ok.
Old 03-06-2009, 10:53 PM   #8
DRIFTWOOD
Driftwood's Avatar
Trade: GEN CONTR.
I,m not Your local inspector. We all do what We have to in Life. I would make it right before selling Your home
Old 03-06-2009, 11:03 PM   #9
the pipe master
Honestly, I you don't notice a u shaped pipe on the roof when you buy the place you deserve to be stuck with it. It's just plain obvious something has been rigged.
Old 03-06-2009, 11:48 PM   #10
The Security Guy...
Thanks for the replies guys!
Actually we aren't selling, the problem is both vents happen to be in the exterior wall and located squarely behind intersecting walls. I have tried to pull the pipes up but their seriously stuck. From the basement I can see the loose connections and the water marks and wall damage, but their not accessable there (couple 90's getting up over the concrete foundation).
To repair this I will be accessing (demo/opening) 4 rooms (both sides of the intersecting walls) in a heavy plastered environment (this home was built to withstand a direct hit from a f4 tornado - after their first was lost to twin tornadoes).
We will be replacing them, just not ready to tear out just yet , so a little "deflection" would be great!
Thanks again...
Jim
Old 03-07-2009, 09:15 AM   #11
DRIFTWOOD
Driftwood's Avatar
Trade: GEN CONTR.
Question
Never heard of doing this on a vent,might work. Co's now specialize in lining
side sewer [ laterals] . Check pipe lining in Your yellow pages,get a free estimate. I'll check else where and get back to You
Old 03-07-2009, 09:44 AM   #12
DRIFTWOOD
Driftwood's Avatar
Trade: GEN CONTR.
Thumbs up
Home owners Insurance MAY pay for demo and new walls. I strongly suggest
You consult an INDEPENDENT insurance adjuster first!look in the in the yellow pages. He of She will write up the claim ,so Your insurance Co. Can't weasel out. Maybe the no glue,should not be mentioned. An independent Adj. will get More $$$$ And write up things YOU or a co. never would! I'm a G.C. that's licensed to plumb. I've done tons of insurance work over the Years. This is GOOD advice! Good luck! This is what insurance is for!
PS. Yesterday heard a mold sickness story. Very sick for years! Was growing mushrooms in His crawl space,took 2 years to figure this OUT! You very well could have mold and serious rot! Ridgid Micro camera will see it all with a 3/4"
hole in drywall about $200 Home depot. I have one! Check it out! Many times, We never hear how it all turns out!
Please don't forget Us!
Old 03-07-2009, 10:06 AM   #13
DRIFTWOOD
Driftwood's Avatar
Trade: GEN CONTR.
Question
The ridgid Micro explorer 30063 inspection camera will take digital pictures
You can down load! Ohio Power tool $690.32. It would make Your damage case. You can sell it later,if You like1 I'd buy it from You at a fair price, if You keep it perfect! I would like one.
ARE YOU SURE THE ROOF FLASHINGS ARE NOT LEAKING ?????
Old 03-09-2009, 01:40 PM   #14
jayson22's Avatar
Trade: Plumbing & Heating
Again, mechanically i don't see any issue. It probably is against code to have the vent pipe pointed down even though it's outdoors. The major issue I see is wildlife like birds using the inner offset to nest in. If they or there nest where to fall in the pipe you could be looking a major blockage in the main drain..that would be my primary concern...
Innovative Plumbing & Heating
Calgary Plumbing & Heating Services
www.innovativeplumber.com
jayson22 is offline
Old 03-09-2009, 11:50 PM   #15
DRIFTWOOD
Driftwood's Avatar
Trade: GEN CONTR.
Red face
Looks like He's gone,bet the carpenter ants aren't!
Old 03-10-2009, 07:22 AM   #16
The Security Guy...
Nope, they try but I'm still bigger!
Maybe a little carpenter cloth over the opening would solve that...
Thanks for all the ideas guys!
Jim
The Following User Says Thank You to Security101 For This Useful Post:
Driftwood (03-10-2009)
Old 03-10-2009, 10:26 AM   #17
bob_cntrctr's Avatar
Trade: renovator
Why not a chimney topper?
bob_cntrctr is offline
Old 03-10-2009, 01:05 PM   #18
gusty60's Avatar
Trade: plumbing
Why not an AAV (studor)?
gusty60 is offline
leak in pex go do it Plumbing 28 12-11-2011 03:40 PM
seal gable vents after ridge vent installed? tacoma5050 Roofing 26 01-18-2008 10:50 PM
Ridge vent issues? apkole Roofing 4 05-08-2007 06:46 PM
Vent stack boots rayh78 Roofing 6 11-18-2006 01:19 AM
vent stack roofed over asbestos Plumbing 4 08-05-2006 02:50 AM
