Chief Toilet Mover
Trade: Bathroom Remodeling
Steam Generators For Steam Showers
What steam generators have you used, what are your favorites and why?
Re: Steam Generators For Steam Showers
Steamist and Kohler. They're both digital, and people like digital. Both basicly the same unit, but the Steamist is cheaper.
Be advised that these units can take up to a 60 amp circuit, so a service upgrade is sometimes required. |
Builder/Remodeler
Steamist...
Straight forward setup & cx. Self cleaning/draining. Have put in two of them & both work very well
![]() Christopher Wright, CR: President @ WrightWorks, LLC/President @ Central Indiana NARI, Named to the 2010 REMODELING Big50 www.WrightWorks.net - Facebook - Twitter - Carmel Remodeling Indianapolis Kitchen Remodeling Contractor - You Can Get There From Here |
No kidding. They are easy. Electrical circuit to the steam generator, and a phone line runs from the generator to the keypad inside the shower. No stupid programming or anything like that. Very intuitive install. You might not even need the instructions.
I know one plumber that had some gripe about where he was going to terminate the T&P valve, but he was a grouchy guy anyhow. Every steam generator has a relief valve. It's a boiler, for pete's sake. |
I just remembered a problem that was related to me about one steam generator install. The contractor was having trouble getting a steam nozzle in the metal finish that the customer had selected for all the other fixtures. I'm not sure if that was resolved or not. I forgot to look when I went back to do my trimout. I know that some people have used the toe tester for a steam nozzle, but that seems like a hazard in my mind. That toe tester sticks out too far, and it would be easy to bump it with your leg and get burned pretty badly.
The Grand Wazoo
Mr. Steam mostly, they are generally smaller than the others. We do condo and co-op work mostly, and size is always a factor.
#7 | |
Moderator
Re: Steam Generators For Steam ShowersQuote:
![]() Where to terminate that T&P drain is quite important. It will dump very hot water and steam if it opens. I've been known to get grumpy while trying to figure out where to terminate one. Code is sorta strict and our inspectors are even more strict.
"My clients’ wishes are the center of my attention." -- David Guido, a contractor in Woodstock, N.Y. New York Times, July 20, 2006 Last edited by Double-A; 01-22-2008 at 05:30 PM. |
#8 | |
The Grand Wazoo
Builder/Remodeler
A preventer? Does it require an annual? Does it matter residential vs. comm?
Re: Steam Generators For Steam Showers |
#11 | |
The Grand Wazoo
We use a 1/2" Watts 007 and use a compression adapter on the outlet side into the generator.
Trade: Plumbing
The last one I installed was 3 years ago it was a steamist. Nice unit!
Have A Blessed Day! |
Chief Toilet Mover
When having a auto clean system are you plumbing this drain line right to the shower drain line?
For instance we are looking at a scenario where the steam unit could be on the other side of the wall of hte shower, basically a common wall between the shower and a walk in closet so the unit would be within 6 feet of the shower drain. |
#14 | |
The Grand Wazoo
#15 | |
Chief Toilet Mover
So how do you handle an open drain in living space? We aren't talking about draining it into the shower right? Seems there would be an issue with that kind of hot water being discharged in there and a burn concern. What are some nice design solutions for an open drain for this thing? |
#16 | |
The Grand Wazoo
#17 | |
#18 |
STEAMKING
Trade: steamshower industry
any of the Thermasol units drain to the shower drain. The water is cooled before exiting into the shower. There are thousand installed chicago.
#19 |
Trade: ooo
This is too funny. Look at the date of the post. I'm pretty sure Finley has it figured out by now.
see ya!
| Steam shower units and anti scald faucets | barehunt | Plumbing | 4 | 02-18-2008 01:30 PM |
| Steam Shower Estimate | TurnkeyConst | Plumbing | 8 | 11-13-2007 09:33 PM |
| Display Steam Generator?? | myshtern | Off Topic (Non Trade) | 5 | 08-22-2007 11:37 PM |
| Sloped ceiling in a steam shower | Eric K | Remodeling | 6 | 08-08-2007 06:16 PM |
| Standy By Generators | Murrayselectric | Electrical | 5 | 01-19-2007 06:48 PM |
