Spray Foam Around Lines ?
Old 01-02-2018, 03:53 PM   #1
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 924
The wall behind this is a poured "interior" wall near the center of home on the basement slab (extending up to the garage above).
The wall is uninsulated. There is roughly an 8" gap between the framing and concrete wall.
If this is foamed, from a maintenance standpoint, would it make repair of a leaky pipe that much harder? Should it be foamed? Heat/AC is not really an issue. This would be done to have a seal on it and help keep the stow under the vanity clean and bugs out. Including for the toilet supply not pictured.
Copper extenders added due to a thicker build-out of the wall after the plumbers did their thing. Please note their joiner locations where foam would be shot.
artinall is offline
Old 01-02-2018, 04:20 PM   #2
tjbnwi's Avatar
Rewards Points: 980
Re: Spray Foam Around Lines ?
Pipe escutcheons, done.
tjbnwi is online now
Old 01-02-2018, 05:55 PM   #3
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 10,030
Why foam it?
Inner10 is online now
Old 01-02-2018, 06:02 PM   #4
tjbnwi's Avatar
Rewards Points: 980
Originally Posted by Inner10 View Post
Why foam it?
I've learned not to ask....
Old 01-02-2018, 06:14 PM   #5
artinall's Avatar
Rewards Points: 924
Why foam it?
As an inquisitive mind once said... "This would be done to have a seal on it and help keep the stow under the vanity clean and bugs out. "
Just seams like committing to the foam might render any future pipe work, more of a challenge. But I don't know, I'm not the expert on exposing/replacing lines. Hence, I'm asking the experts.
I did the drywall/finishing and now ready to have the vanity installed ...
artinall is offline
Old 01-02-2018, 06:33 PM   #6
tjbnwi's Avatar
Rewards Points: 980
Again---pipe escutcheons.
Old 01-02-2018, 06:37 PM   #7
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 584
If it's an interior wall, any bugs would already be inside the envelope anyway, so not much point in sealing an area they can already get at from both sides.
Foam would gunk up the outside of the pipe and have to be cleaned off before sweating any new connections. Just stuff the gaps with fiberglass if you must, put escutcheon plates on and be done with it.
Tinstaafl is online now
artinall (01-02-2018)
Old 01-03-2018, 07:24 AM   #8
brickhook's Avatar
Trade: masonry
Rewards Points: 6,264
Ive knocked prettier holes than that, in block walls with a hammer
....a wise man once said " a Brick Mason has no business in the plumbing section"
...Ill shut the door on my way out
brickhook is offline
Old 01-03-2018, 08:12 AM   #9
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 20
Spray foam or other sealer should be done at the framing, coming out of the wall is not required. With that said it won't hurt to do it BUT it shouldn't really be done until after the shutoffs are installed, etc... (which is a pain)
As for harder for pipe repairs, well I would hope that there shouldn't be any, the only time it should become an issue is if they decide to remodel again & to move the lines in which case it becomes mute. Personally I would caulk it & slap the escutcheon on
SLSTech is online now
The Following User Says Thank You to SLSTech For This Useful Post:
artinall (01-03-2018)
Old 01-03-2018, 08:16 AM   #10
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 10,593
Yes, repairs would be more difficult.
No, it should not be foamed.
It looks like the drain hook-up might be the fun part.
MarkJames is offline
Old 01-03-2018, 08:34 AM   #11
Inner10's Avatar
Pipe repairs? If you need to get that close to the wall you're cutting a hole anyway...big deal you gotta pick off some foam...but still I don't see the reason to do it in the first place.
Old 01-03-2018, 09:51 AM   #12
artinall's Avatar
Rewards Points: 924
If you only saw the surrounding framing.
...just checking the door latch.
- You see the plumbers did such an outrageous hack job on this bath they've got me questioning everything little thing they touched.
artinall is offline
Spray foam insulation and Vapor barriers in bathrooms Zenscapes.ca Remodeling 9 10-22-2012 08:01 AM
Spray Foam Insulation Bastien1337 General Discussion 6 01-12-2011 08:02 AM
Soy Based Spray Foam ApgarNJ Insulation 9 08-05-2010 09:36 AM
how does spray foam not bow the window? contractorjay Windows, Siding and Doors 13 04-27-2010 10:46 AM
foam spray gun vs canned foam AustinDB Tools & Equipment 4 12-03-2008 08:30 AM
