Split ABS Drain Pipe
Old 01-24-2010, 03:22 PM   #1
bathroom guru
jarvis design's Avatar
Hey guys (and gals!)
I just saw the strangest thing at a buddies place:
He had a leak in the 1 1/2" ABS drain pipe leading from his kitchen. A 6' section of pipe has split (almost the entire length) lengthwise. Another piece had a split around the circumfrance.
I have been doing bathrooms/renos for 20+ years - never seen anything like it.
It is on an outside wall - but inside the insulation
The only explanation I could give was he had some crappy pipe.
Anyone else seen this?
Bathrooms Built for Life.
www.JarvisDesignBuild.com
519-495-4062
jarvis design is offline
Old 01-24-2010, 03:52 PM   #2
rselectric1's Avatar
Re: Split ABS Drain Pipe
Is there a clean out somewhere in this run where someone could have applied way too much torque in screwing a plug back in?
Otherwise it defies logic. The supply pipes are intact and in the same general area?
rselectric1 is offline
Old 01-24-2010, 04:04 PM   #3
Master-Pro-Plus
GregC's Avatar
Trade: Master Plumber/Pipefitter,General Contractor, Plus
Hello, yes most likely a defect in the pipe during manufacturing(weak fusion at seam or at roll off/cutting stage) I have seen a few of these. ABS is not the greatest thing these days. PVC, no doubt better choice.
I have seen a lot of different things in the manufacturing end of it and sometimes the quality control allows a few things get by more than once.
GregC, www.gjcicionegeneralconstruction.com
GregC is offline
Old 01-24-2010, 05:06 PM   #4
Tom Struble's Avatar
Trade: siding
hey Greg nice belt system
Tom Struble is online now
GregC (01-24-2010)
Old 01-24-2010, 05:15 PM   #5
Are you the guy in the red shirt?
PS-be very careful about promoting your product here. In other words, don't do it. With your plumbing background you will be a nice addition to the forum. Let us come to you about the belt (it's pretty cool though)
The Following User Says Thank You to rselectric1 For This Useful Post:
GregC (01-24-2010)
Old 02-01-2010, 03:27 PM   #6
User
TravelTradesman's Avatar
It was probabally made in China. I saw this once with copper pipe. We took a loss on that one!
J&J Plumbing and HVAC
TravelTradesman is offline
Need some help w/ a broken pipe BuiltByMAC Electrical 48 01-22-2010 11:07 AM
Drain Pipe denick Excavation & Site Work 18 07-12-2009 04:41 PM
roof drain pipe clogged Grumpy Plumbing 11 09-19-2008 10:00 PM
odd find for drain pipe 72chevy4x4 Plumbing 9 11-06-2007 10:48 PM
How to rock around drain pipe that stick out 1/4in from stud? ruskent Drywall 11 04-27-2006 12:02 AM
