Source For Smoke Bombs???
Old 01-08-2007, 08:50 PM   #1
a1plumbingyakim's Avatar
Trade: Plumbing Contractor
I need to smoke a vent to find a sewer smell in a ladies house, she had a remodel done about 4 years ago and in the last 6 months developed a sewer smell in the basement beneath the remodel (an opening in the closet is letting the smell in i'm sure) I replaced the wax ring as a precautionary but it still stinks, so... i want to smoke the vents and see if we can find it that way so we aren't tearing up her walls for nothing. I don't think it has to do with HVAC because the smell is localized, Sooo do you guys know where i can get some smoke bombs/machine that won't catch anything on fire, and help me with this. TIA
Rob
a1plumbingyakim is offline
Old 01-08-2007, 09:09 PM   #2
Pro Plumber
Ron The Plumber's Avatar
Trade: Plumber
Re: Source For Smoke Bombs???
If you can't find the smoke bombs now about........
Pulling traps, capping lines, pull toilets, pluging them, and plugging tub, fill woth water, do a test on the system just as you would in a top out.
Ron The Plumber is offline
Old 01-09-2007, 05:46 PM   #3
mdshunk's Avatar
Tool rental and party supply rental stores rent smoke generators. Just rang up my rental store just now, and they're 15 dollars a day. They're intended for haloween special effects and dance floor special effects. I know it would do a fine job for what you need. I used one several years back to diagnose a "cold spot" in an office building. I pumped a little smoke from the machine to see how the airflow was. Acutal "smoke bombs" are sold at HVAC supply houses to diagnose heat exchanger holes. They only last a minute or two, and might not be long enough for you to run around and look for your leak. The smoke machine from the rental has a tiny blower, so it would sorta somewhat pressurize your like to declare the leak better or quicker.
mdshunk is offline
Old 01-11-2007, 12:51 AM   #4
Thanks, i'll check in the morning, i though it might be a bit tough smoking the vent with a smoke bomb, the smoke machine is definitely the way to go...
Where do you source ducting? Vermaraj HVAC 5 07-18-2007 11:22 PM
Wholesale source for NOLO..grasshopper bait? Jacey Landscaping 0 04-19-2007 09:49 AM
source for relay? Atricaudatus Electrical 9 02-18-2007 05:48 PM
source for lumber prices 72chevy4x4 Construction 10 11-03-2006 01:22 PM
Hardwood Floor Scraping Tool Source Anyone? Grainywood Flooring 2 04-27-2006 05:49 PM
