Unregistered
Guest
Posts: n/a
Sometimes I Have No Hot Water
My hot water tank appears to functioning normally, most of the time. Here's an example of my problem: there was no hot water use all night. when i went to use the hot in the morning there was none. after running the hot water that wasn't hot, i looked at the tank and i could see and hear that is was on and heating up. about an hour later there was plenty of hot water. i think that sometimes the thermostat (or something else) is not turning on the burner. the tank is about 10 years old which is the life expectancy. does this sound like a problem that if i replace a thermostat or something it's fixed or do i probably need to replace the entire unit? thanks...email - danfine1@aol.com
Unregistered
Guest
Posts: n/a
Re: Sometimes I Have No Hot Water
probably won't help, but...
maybe the thermostat is sitting in a bunch of sediment, which is getting stirred up when you run the water... drain the tank. |
| #&*@! Water Hammer! | Mike Finley | Plumbing | 19 | 02-22-2007 11:47 PM |
| Water Tiles with well water? | depriate4repair | Plumbing | 10 | 02-15-2007 08:11 AM |
| Help Water in Basement | LG2720 | Construction | 12 | 01-17-2007 02:40 AM |
| Hot Water | Joewho | Plumbing | 13 | 11-17-2006 02:39 PM |
| Brick Footer and Water Proofing | emtaboy | Excavation & Site Work | 24 | 07-24-2006 09:48 PM |
