Soldering Copper To Brass?
Old 08-15-2009, 09:18 PM   #1
wayne3434's Avatar
Trade: carpenter/remodeling
my plumber cut a brass pipe which had a nipple at the end so it was thicker than the copper coupling. He sanded it down to make the copper fit and then soldered it. Did anyone ever hear of this and do i need to worry about it leaking?
wayne3434 is offline
Old 08-15-2009, 09:24 PM   #2
BCConstruction's Avatar
Trade: Construction
Re: Soldering Copper To Brass?
It's fine
BCConstruction is online now
Old 08-15-2009, 10:17 PM   #3
Official CT Greeter!
CScalf's Avatar
Trade: General Construction
j/k it will be fine, i hope, well i think, well you know i am just not sure anymore....
"Your problem does not constitute an emergency on my part"
CScalf is offline
Old 08-15-2009, 10:24 PM   #4
Pompass Ass
bwalley's Avatar
It is fine, if it didn't leak when he pressurized the system, it most likely will never leak.
bwalley is offline
Old 08-15-2009, 10:39 PM   #5
Fentoozler
Celtic's Avatar
What is this valve made of ?
You'll probably find a dozen or so joints sweated between copper and brass in your home.
Celtic is offline
The Following User Says Thank You to Celtic For This Useful Post:
mrmike (08-16-2009)
Old 08-15-2009, 10:47 PM   #6
Trade: Construction
They are Join freindly because of the amount of copper content in brass. Some people have problems getting the solder to take when mixing metals but it's because of over heating the copper as the brass takes a little longer to heat up than the copper. But if he's a proper plumber it will be fine.
Old 08-16-2009, 09:03 AM   #7
DetailHandyman's Avatar
Trade: Professional Handyman
Ooo, ooo, I know! Brass! and maybe some steel there...with a vinyl coating...and perhaps a SS ball inside and...
The cat box ain't gonna clean itself.
DetailHandyman is offline
Old 08-16-2009, 11:39 AM   #8
Cabinetmaker
skymaster's Avatar
Trade: Cabinetmaker
Send a message via AIM to skymaster
Teflon!!!!!!!!!!!! ya fer got da Teflon Don NOW Youse is gonna git it!!!!!!!
skymaster is offline
Old 08-16-2009, 12:23 PM   #9
JonM's Avatar
Bell metal= One part tin, 4 parts copper......
JonM is offline
Old 08-17-2009, 09:02 PM   #10
tinner666's Avatar
I've done it many times. Never an issue.
Frank Slate Roof Repairs, Richmond, Va.
tinner666 is offline
Old 08-26-2009, 09:42 PM   #11
plumbworker's Avatar
Trade: Plumbing / Fire Protection / Hydronics / Service
thats hack! the codes states the use of approved fittings sanding and modifying a brass nipple and soldering a coupling to it is not approved sure it works but is just wrong he could have sweated on some fip adapters and threaded to the brass nipple.
plumbworker is offline
Old 08-26-2009, 09:53 PM   #12
Trade: Construction
I dont think he cares that he didnt use an "approved" fitting but wants to know if the soldering from brass to copper was ok. I wouldnt give a dam as long as it was fine after a pressure test.
Old 08-26-2009, 09:55 PM   #13
Old 08-26-2009, 10:02 PM   #14
Trade: Construction
I was told by a building inspector once that i couldn't use brass olives on compression fittings. He didn't have a reason as to why so i had to explain to him why i didn't use brass olives anyway and swapped them out for copper. The idiot didn't even know the reason why you wernt meant to use brass. Some of these codes are just stupid.
Old 08-26-2009, 10:13 PM   #15
whats a olive? you mean ferrule?
Old 08-26-2009, 10:20 PM   #16
slowforthecones's Avatar
Trade: scab
hey plumbworker, good to see another plumber from the city (s.f.). SF DBI sucks....
I also do plumb/elec/fire protection. We are a small community here.. Mazzy's sucks. bunch of hacks.
slowforthecones is offline
Old 08-26-2009, 10:27 PM   #17
moraga? thats near orinda right? the dept does blow
Old 08-26-2009, 10:43 PM   #18
Trade: scab
Yup Moraga near Orinda but I own multiple residential apartment bldgs in the city. I work in the city too and some inspectors seem to have a strong preference for particular fire protection firms to have "no hassle" inspections. I deal with DBI often enough and they are a bunch of bottom feeding homosexual blowers.
Old 08-27-2009, 10:40 AM   #19
Trade: Construction
Nope i mean olive. You normally get them with brass olive but they have to be strangled so much that you cant ever get them of the pipe and they can be over tightened. I just change them all out with copper and never have the issues involved with brass versions. Most good quality fittings will come with a copper olive for this exact reason. But some of thr cheaper ones just bundle brass.
Old 08-27-2009, 03:08 PM   #20
Fentoozler
Celtic's Avatar
I've never heard that item referred to as an "olive"...only as a ferrule
Celtic is offline
Copper roofing Trimac Roofing 2 08-21-2008 10:42 PM
Soldering 4" copper lines mastadon Plumbing 7 12-01-2006 01:30 PM
Painting new gal. gutters copper DeanV Painting & Finish Work 0 06-22-2006 09:39 PM
