Slow Flusher
Old 03-12-2007, 06:45 PM   #1
fast pasquale's Avatar
Trade: Hardwood flooring contractor
Slow Flusher
Got a toilet on a 2nd floor (old 3 gallon).. anyways.. ive never had a problem with it flushing ...but when i hit the handle it flushes so darn slow.. why is this???
Chris Frate
Pasquale Floors
fast pasquale is offline
Old 03-12-2007, 06:50 PM   #2
Teetorbilt's Avatar
Re: Slow Flusher
Drain blockage/restrictions. Could also be a low level in the tank.
Albert Einstein
Teetorbilt is offline
Old 03-12-2007, 10:11 PM   #3
Pro Plumber
Ron The Plumber's Avatar
Trade: Plumber
Re: Slow Flusher
Toilet fush ring need the holes cleaned.
Ron The Plumber is offline
Old 03-12-2007, 11:21 PM   #4
Re: Slow Flusher
Ron.. i think that's it!.. I originally thought that was it b4 i posted. The water level is good and i don't have a drainage blockage. How would i go about cleaning those???
Chris Frate
Pasquale Floors
Old 03-12-2007, 11:33 PM   #5
Teetorbilt's Avatar
Re: Slow Flusher
It's really pretty simple. water in, water out. If the tank is to level when you flush, it has to be in the drains.
Albert Einstein
Old 03-13-2007, 12:05 AM   #6
Re: Slow Flusher
just got the drains snaked and the other two toilets (on the same drain), flush perfectly.
Could i blow out the holes with a compressor??... obv. low pressure
Chris Frate
Pasquale Floors
Old 03-13-2007, 01:20 AM   #7
Pro Plumber
Trade: Plumber
Re: Slow Flusher
I use a allen wrench folding set, start with a small one, wiggle it around in each hole. then move up in size, till it opens them up more then they are.
Old 03-13-2007, 03:36 PM   #8
boman47k's Avatar
Re: Slow Flusher
Ditto the flush ring. Coat hanger, stiff wire, torch cleaners might be some other things to try to get the crud out.
boman47k is offline
Old 03-13-2007, 06:56 PM   #9
painterman's Avatar
Trade: Historic Restorations
Re: Slow Flusher
Try removing all the water from the bowl and pouring some CLR in it ,let it sit over night. Spray the underside where all the small holes are aswell. You will not believe the crud that will come loose when you flush it.
painterman is offline
Old 03-13-2007, 07:07 PM   #10
boman47k's Avatar
Re: Slow Flusher
Concentrate on the rodding the flushring out. If that does not solve the problem, I think I would try and auger on the toilet itself. The auger would not hurt anyway. Strange things can get in the toilet.
boman47k is offline
Old 03-16-2007, 07:30 AM   #11
gitnerdun's Avatar
Trade: plumber
Re: Slow Flusher
Make a temp plug out of toilet paper, shove it into the jet siphon hole in the bowl. Then you pour CLR or muriatic (my favorite) in the overflow tube in the tank. This will clean the rim. Let sit for 30 mins, then flush and carefully remove the paper.
gitnerdun is offline
Old 03-16-2007, 07:38 AM   #12
boman47k's Avatar
Re: Slow Flusher
muriatic? and remove very ycarefully? Whew, I'd say VERY carefully,....if I all! Strong stuff! Heheh, I'd be scared to turn the light on/off when those fumes build up in a small bathroom. Maybe I am too cautious though.
boman47k is offline
Old 03-16-2007, 10:29 PM   #13
TurdMaster's Avatar
Trade: Mechanical Contractor
Re: Slow Flusher
Save yourself some hassle and future trouble. That toilet wont flush good anymore because of hard water deposits inside the toilet itself. You can ream the little holes out all you want to but inside the passageways it will still be loaded with buildup. Dont be so cheap, go buy an American Standard Cadet 3 with a 3" flush valve that flushes as good as any 3 gallon toilet ever did for 125 bucks.
TurdMaster is offline
Old 03-17-2007, 12:22 AM   #14
Pro Plumber
Trade: Plumber
Re: Slow Flusher
I have always been able to get a toilet with clogged up flush ring holes to flush good after cleaning them out, so saying it won't work good anymore is not entirely ture, I have never replaced one yet.
Old 03-17-2007, 08:45 AM   #15
gitnerdun's Avatar
Trade: plumber
Re: Slow Flusher
The acid works on the crusties in the rim and siphon hole that you can't get at with wire. Turd boy is right about it being a good way to sell a toilet by not fixing.
Old 03-27-2007, 11:07 AM   #16
ozmy6's Avatar
Trade: Diesel Fitter
Re: Slow Flusher
Is it true that you can pour the acid into water, but never water into acid? I allways think of that when I here toilet and acid.
Good news for people who love bad news...
ozmy6 is offline
Old 03-27-2007, 03:27 PM   #17
boman47k's Avatar
Re: Slow Flusher
I'm thinking that has do with splash danger. We have a substance here we sometime use for cleaning main drain lines. Pour it down the soil stack or vent usually, and we do not look down the pipe to see if it makes it to the bottom! Also kind of step back if pouring lye or any acid like substance down a basin drain in case of violent reaction.
boman47k is offline
Slow Down Ron The Plumber Site Help and Suggestions 21 08-19-2007 03:29 PM
slow on work, anybody have work to spare saucedo80 Painting & Finish Work 2 02-08-2007 07:06 PM
Starting Slow, Working Weekends Bertram General Discussion 13 06-30-2006 12:03 AM
am I slow? cynthiann Painting & Finish Work 9 05-10-2006 09:04 PM
If Your Slow, What Not To Do keithguts General Discussion 2 01-24-2006 07:25 PM
