Trade: general
Slow Draining Vessel Sink
Just installed new vessel sink, new trap, new drain line, sink drains very slowly. Drain is non pop up no overflow. When drain is disconnected with just tail piece and trap connected emptying into bucket drain is extremely slow. Any suggestions.
Trade: plumber
Re: Slow Draining Vessel Sink
Try A Different Type Of Drain. Maybe A Lift And Turn.
Moderator
Was it slow from the moment you installed it or did you get called back on it?
Have you dropped the trap and looked for a blockage? This one is a real stumper... What type of drain is installed? You say non pop-up and non-overflow. Is there a screen or grid that is covered with some plastic perhaps?
Trade: general
It is slow from the moment it was installed. Tried a mushroom type fixed drain without overflow, and tried a open grid without overflow. Both drained slowly. It seems to be an air issue prior to reaching the trap. Is there a way to admit air into the system prior to the trap.
No plumber but have to ask. Vented proprerly??
| The Following User Says Thank You to boman47k For This Useful Post: | Driftwood (03-10-2009) |
Don't ask, but sometimes there might be a couple of "extra" compression washers stuffed into a semi-cast trap--right from the factory!
For some people, this could take 2 or 3 hours to discover.
Put your location in your profile! (Sorry....it seems there really are dumb questions) Last edited by neolitic; 11-27-2007 at 12:38 PM. |
Trade: general
no semi cast trap, all pvc. The venting on the line is fine. The sink empties into a 3" vented drain. Shower and toilet all empty into same 3" line and have no problem draining. Once I loosen trap (still not connected, just draining into bucket) enough to allow air in, drain drains great. Once everything is tightend back up (still draining into bucket) drain creeps to a crawl.
Trade: General
Sounds very similar to "vapor lock". Makes total sense to me not having an overflow which provides some venting. I had a regular sink at a job site which had the same symptoms. We took the trap off, clean, we snaked the drain line, clean. One of my cowarkers picked up a plunger and and plunged the sink drain, low and behold a slug of something came shooting out of the overflow hole. Fixed.
The only thing I can come up with is a studor type valve installed ahead of the trap to help vent. Forum? |
Chief Toilet Mover
Trade: Bathroom Remodeling
Sounds to me like a typical vessel sink.
Everyone we install is just like that. It seems to be the nature of the beast by the way those special vessel sink drains are constructed. |
Pro Plumber
Trade: Plumber
Grid strainers are always a problem, those little holes the water flows through can and will create air bubbles in them, causing it to drain slow, try this, when it's draining slow, run finger over the holes in the strainer, your finger will break the bubble making it drain better, see what happen, if this works there is your problem.
#11 | |
Trade: plumbing
Re: Slow Draining Vessel SinkQuote:
The Grand Wazoo
Pull the grid drain out and replace it with one of these.
Professional Remodeler
I agree with Mike, everyone I've ever installed seems to drain slow just like yours. Everyone else is right, it's just something to do with the way the air bubbles are trapped underneath the grid.
-Mike- Falcon Contracting Residential - Commercial
Same here. After the plumbers install, I always shut down the supply stops until the faucet does not overtake the drain rate. No one usually knows any different, and if customer does happen to comment on flow rate, I will either tell them what I have done and why or curse those "new flow restricted faucets", depending on the customer.
#15 | |
Trade: Plumbing
Paradiso Plumbing Inc. |
| Need help! Hole for sink cut too big! | sage | Plumbing | 32 | 02-05-2009 03:10 PM |
| sink draining to slow | nywoodwizard | Plumbing | 23 | 11-02-2007 08:50 PM |
| Kitchen Sink Is Clogged!! Any Suggestions | madi5 | Plumbing | 4 | 08-24-2007 02:12 PM |
| vessel height? | go dart | Plumbing | 14 | 06-05-2006 07:15 AM |
| Bathroom sink question | Robie | Plumbing | 6 | 12-07-2005 10:23 PM |
