Slab On Grade Curbless Shower
Old 09-12-2017, 10:40 AM   #1
climb's Avatar
Trade: Cabinetmaker / Finish Carpenter
Rewards Points: 44
What is the best way to do a 48" x 48" curbless (zero entry) shower with a slab on grade? One wall of the shower will be on an exterior wall. Plumbing wall is interior. I'm thinking about a few different approaches:
1. Our the slab with a 49"x49""2" piece of foam in the slab, then pull it out after the concrete hardens. This will create a recess in the concrete. Then I can set a shower basin OR fill, slope and tile after the walls are up.
2. Maybe I'm overthinking it and I should just have the concrete guys slope the floor to the drain and tile it. Would code require a trench drain this way?
I am planning on using Kohler Choreograph Shower walls (solid surface type wall panels).
climb is offline
Old 09-12-2017, 01:20 PM   #2
tgeb's Avatar
Rewards Points: 330
Re: Slab On Grade Curbless Shower
If you recess the slab with the foam sheet, make certain to also recess the subgrade so you maintain the proper slab thickness.
www.gebcon.com
tgeb is online now
The Following User Says Thank You to tgeb For This Useful Post:
Californiadecks (09-12-2017)
Old 09-12-2017, 06:16 PM   #3
B.Johnson's Avatar
Trade: Builder
Rewards Points: 612
Just form it with a 2" form and pour it. I wouldn't trust most concrete guys to get the slope correct, but if you have a REALLY good guy, then go for it.
Home Designer Series Software
B.Johnson is offline
Old 09-12-2017, 10:03 PM   #4
climb's Avatar
Rewards Points: 44
That's what worries me. These guys are ok, but...
climb is offline
Flashing A Wall Sill Plate On Slab On Grade philcav7 Construction 18 03-24-2017 08:52 PM
Pouring Concrete 5 inch "Overlay" w/ curbless shower Ajeagle6921 Flooring 6 01-20-2017 09:08 AM
Custom shower base - granite Charles_cz Tiling 16 01-08-2015 09:34 PM
? Curbless shower with wood floor joist sycamorebob Tiling 8 11-04-2012 10:18 AM
slab on grade mjaafreh2008 Construction 10 02-16-2009 08:35 PM
