Carpenter/fencing
Sink Draining To Slow
All new plumbing has been installed.apparently there was a problem venting the kitchen sink (windows and obstructions),so the plumber puts an island vent in downstairs with a p-trap in the basement. My freind calls me over and asked if i could help install the new sink ,the problem is the waste line coming out of the wall was too high,so it needed the p-trap to drop the height to connect the tail piece to the sink.The sink is draining way too slow, i'm assuming too many traps now?. I guess the only fix is to break open the wall under the sink base and cut the waste line down lower and install a 45 and just remove the trap under the sink?
Learning without thought is labor lost; thought without learning is perilous. |
Trade: master plumber/owner
Re: Sink Draining To Slow
I'm not really getting the image in my head, but a drain should never be double trapped. The trap needs to be under the sink and I do not know why there would be a trap in the basement. If you could post a picture it would help. Did this not get inspected?
Al Smith
Our plumber Bruce showed us this method of island venting recently.
Does your vent look like this? island vent |
Trade: Plumbing
I'm not sure what you're talking about. An island sink doesn't have a trap under the floor.
Island Sink (illustrated) (edited to add: Whoops, A.W. beat me to it . . .)
There are no dumb questions - just a lot of inquisitive idiots. |
#5 | |
Carpenter/fencing
Re: Sink Draining To SlowQuote:
Al Smith
the only time I have seen traps under the floor is for tubs and showers. You sure that was a plumber and not a handyman?
If it is trapped under the sink and then 90s down that is an s-trap and it's illegal due to the trap sucking vacuum that it creates. There should be a sanitaty tee in the wall that the trap arm/sink drain goes directly in to. Above this san-t there needs to be some form of a vent like an island vent or studor vent. I prefer the island vent.
I would ask to see that license |
The Grand Wazoo
A fixture that is double trapped will become airbound, and drain painfully slow.
Three Rivers Services LLC
Re: Sink Draining To Slow |
Why not just rip it out and do it right? It would be hard to install a studor vent between the traps to relieve the pressure, plus it is frowned upon to put a studor vent that far beneath the flood level rim of a fixture if you put it in the basement
#11 | |
This "S" trap, covers those suckers that trap and then sweep back down through the floor? I've had a few women that had their "designers" sell these thing to them.
#13 | |
Trade: hjrafiuoashfed
I did the small and quick repair and got the heck out of there. I wouldn't give the customer a receipt and demanded cash because I didn't want a paper trail to that abortion. In a another Studor vent example, it was venting a full bathroom in a cabin. The Studor was located in the basement, a good 5' below the fixtures. Someone ought to complain about Studor vents.... |
#14 | |
Plumber
Trade: Plumbing
#15 | |
FT.WORTH,TX MASTER PLUMB
Trade: plumbing
YESTER DAY IS HISTORY, TOMORROW IS A MYSTERY http://paradiseplumbinganddrains.com...bers-dallas-tx |
Carpenter/fencing
Here's what it looks like ,the pipe leading off the trap goes to the sink upstairs,the other goes to the vent stack,i can see its going to be a mess to fix,kitchen is complete with granite tops.The cabinet back would have to be cut open to make the proper repairs,from the look of the photos i've seen.
Carpenter/fencing
forgot the picture ,here it is
#18 |
Al Smith
why would you need to open the cabinet back? Just drill two holes in the floor inside the cabinet and then through the sub floor and install a new drain and vent loop. abandon and cap off the inaccessible pipe behind the cabinet.
#19 | |
Carpenter/fencing
![]() i guess i was just thinking cosmetics. the cabinet its stepped out 4" off the wall,i was just considering removing the back, installing the new piping where it can't be seen and just put a new back in. But if my knucklehead friend don't mind i'll do it thru the floor of the cabinet. thanks
#20 |
The damage is done so the easiest fix without demo would be to get rid of that trap below the floor. Throw a sanitary tee with a riser coming up after the trap under the cabinets and put a studor vent as high as you can get it under the sink. Or you can cut out the back of the cabinets and run an island vent. I would do the island vent, but I figured Id give you another option.
I do not see any primer on those pipes either. Last edited by The plumber; 11-02-2007 at 06:49 PM. |
| Need help! Hole for sink cut too big! | sage | Plumbing | 32 | 02-05-2009 03:10 PM |
| Kitchen Sink Is Clogged!! Any Suggestions | madi5 | Plumbing | 4 | 08-24-2007 02:12 PM |
| Starting Slow, Working Weekends | Bertram | General Discussion | 13 | 06-30-2006 12:03 AM |
| Bathroom sink question | Robie | Plumbing | 6 | 12-07-2005 10:23 PM |
| sink pump | zbwmy | Plumbing | 1 | 11-11-2005 03:47 PM |
