Silicone Caulk Around Toilet Base
Old 12-30-2009, 01:39 PM   #1
Back from the dead...
ProWallGuy's Avatar
Trade: Paperhanger/Painter
Rewards Points: 7,510
My toilet has a slow leak. Around the base of it where it meets the floor, I find a small (3" X 9") puddle every morning. If I get my sock wet first thing in the morning one more time, I might kill everyone in the house.
Rather than yank the toilet, or try to remove all the existing silicone, can I caulk over it with more silicone to stop the ooze?
TIA
ProWallGuy is offline
Old 12-30-2009, 01:45 PM   #2
Anti-wingnut's Avatar
Rewards Points: 3,304
Re: Silicone Caulk Around Toilet Base
Yes, if you want to remove the toilet in a year. And tear up the floor covering, rip up the sub floor, and replace the rotted joists.
If you do not want to repair dry rot, fix it correctly right now
Anti-wingnut is offline
The Following User Says Thank You to Anti-wingnut For This Useful Post:
slowsol (08-22-2011)
Old 12-30-2009, 01:48 PM   #3
solar guy
naptown CR's Avatar
Trade: solar contracting
Rewards Points: 1,000
You have a leaking something most likely a wax ring. caulking to keep it from flowing out onto the floor may keep the socks dry but if this toilet is on a wood framed floor you will rot out the subfloor below the toilet and may someday end up in the level below while taking the morning constitutional.
Best thing is to remove the toilet, find the source of the leak and do a proper repair.
Make sure the toilet flange (the thing the toilet bolts to) is on TOP and above the finished floor.
Replace the wax ring with the thickest no seep (The one with the horn that goes down into the drain) wax ring you can find.
Besides do you know what you are stepping into?
This should take no more than an hour to do Maybe 2 including a run to the store.
naptown CR is offline
Old 12-30-2009, 02:08 PM   #4
General Contractor
ASMCHICO's Avatar
Trade: Multifamily Maintenance/Remodel
I agree, this should be fixed now. As others have mentioned, you don't want to get any rot. Even if you are on a slab, many times the water will damage whatever flooring you have. I would suggest you thoroughly inspect the toilet during flushes & make sure the leak is not coming from the tank (toilets can be very deceiving sometimes). Maybe even rock the tank very slightly, making sure the gasket is holding ok. If it is the ring, it is a basic repair & should not take too long. If the flange is up too high to be covered by the toilet, be sure to shim the base so the wax can work. I see this a lot in slabs.
Good luck!
ASMCHICO is offline
Old 12-30-2009, 02:10 PM   #5
ProWallGuy's Avatar
Thanks, I pretty much knew all this, but wanted to be able to print this out and show the wife so she will get off my back about caulking the thing.
Yes, I gave it a taste test. I didn't taste like pickle juice, so I assume it's water.
The Following User Says Thank You to ProWallGuy For This Useful Post:
ChrWright (12-30-2009)
Old 12-30-2009, 02:12 PM   #6
solar guy
naptown CR's Avatar
You are a braver man than I.
Check the tank connection. and the fill valve I have seen these squirt up and hit the lid and leak down outside the tank.
Old 12-30-2009, 02:13 PM   #7
IHI's Avatar
Rewards Points: 1,040
I prefer to just permanantly remove the toilet from the house, that way there is nowhere for the water to leak from, no wax rings to worry about failing. Just get a piece of PVC pipe to slip down inside the waste line, install a few elbows to make a trap and insert a funnel- problem solved.
Just be cautious when dropping a duece, you may need to make a stick holder to push it down the funnel tube
IHI is offline
Old 12-30-2009, 02:31 PM   #8
The Grand Wazoo
KillerToiletSpider's Avatar
Rewards Points: 1,864
Get one of these.
KillerToiletSpider is online now
Old 12-30-2009, 02:36 PM   #9
solar guy
naptown CR's Avatar
Originally Posted by KillerToiletSpider View Post
Get one of these.
that must be the deluxe model
Even has what looks to be Poison Ivy growing in it to wipe with.
Old 12-30-2009, 02:57 PM   #10
The Grand Wazoo
This is the deluxe model.
Old 12-30-2009, 03:06 PM   #11
Shawn Prentice's Avatar
Trade: carpenter/remodeler
Rewards Points: 250
It's not that big of a deal to pull/reset a toilet and you'll be glad you did once the problem is fixed. A slick trick my plumber taught me to get the water out of the bowl and tank is to suck it out with a wet vac.
Shawn Prentice is offline
Old 12-30-2009, 03:24 PM   #12
Santa's Helpers's Avatar
Trade: Repair and remodeling
Rewards Points: 95
Amateur
A professional sloshes the water around like a marble in a maze, without spilling a drop. I have seen more than one of my guys dump it down the front of their pants.
Santa's Helpers is offline
Old 12-30-2009, 03:29 PM   #13
IHI's Avatar
What's wrong with a piece of clear tube and siphoning it out?? man some guys make this harder than it needs to be
IHI is offline
Old 12-30-2009, 03:31 PM   #14
ProWallGuy's Avatar
I'm a bit disappointed.
I'm still waiting for Ron the Plumber to show up and tell me to hire a pro.
Old 12-30-2009, 05:14 PM   #15
slowforthecones's Avatar
Trade: scab
allright this is how I do it and I do it atleast once a week new water closet or remove/replace.
1) turn off water to toliet & disconnect water supply line.
2) flush toliet and use plunger a few times to drain toliet bowl water
3) run a utility knife around the area caulked if caulked
3) unscrew bolts & remove toliet
4) clean area of old wax
5) install new bolts and wax ring,
6) use two screw drivers on each side 9 & 3 oclock position to indicate the position of bolts
7) drop toliet in... tighten bolts
8) hookup water supply line.... test flush, use flash light to inspect for leaks.
slowforthecones is offline
Old 12-30-2009, 07:55 PM   #16
stp57's Avatar
Trade: carpenter/ handyman
Hey Slow,
I didn't know that you could drain the toilet with a plunger. Thanks for the tip. I hate the idea of using my wet vac on a toilet.
Steve
stp57 is offline
Old 12-30-2009, 08:11 PM   #17
rselectric1's Avatar
Rewards Points: 586
I dump a half filled 5 gallon bucket of water in the bowl to get rid of some of the water (try it and you'll see) and use a sponge to get rid of the rest.
(although there will always be water in the gooseneck)
rselectric1 is offline
Old 12-30-2009, 08:33 PM   #18
DarrenB's Avatar
Trade: VA Contractor (bathrooms)
Rewards Points: 75
I call top floor.
DarrenB is offline
The Following User Says Thank You to DarrenB For This Useful Post:
kcremodeling (09-16-2011)
Old 12-30-2009, 08:39 PM   #19
The Grand Wazoo
You guys work way to hard to get the water out.
Takes about two minutes.
Old 12-30-2009, 08:45 PM   #20
Teetorbilt's Avatar
Rewards Points: 2,000
I go the wet vac route, you won't get it all out but a towel will clean up.
Install new wax ring and level the bowl with shims.
I use grout on tile/solid surfaces and caulk on wood/laminates. I also always leave about a 1" gap in the back so that you'll know when it goes bad next time.
Nothing worse than a sealed toilet base. Usually months of collected stuff full of those little flatworms and maggots.
Hope that you're not reading this while eating.
Albert Einstein
Teetorbilt is offline
how to paint silicone caulk rocco Painting & Finish Work 19 05-29-2013 06:07 PM
Need a good base molding solution soon! HandyHails Finish Carpentry 16 03-17-2009 06:46 PM
Silicone Caulk JonM General Discussion 12 07-29-2008 12:02 AM
Toilet Challenge Vermaraj Plumbing 40 11-09-2007 08:04 PM
Removing silicone caulk ron schenker Painting & Finish Work 8 02-07-2007 07:33 PM
