Shower Pan
Old 09-29-2008, 12:46 PM   #1
Plumber / Carpenter
Bill's Avatar
Trade: Virginia Building and plumbing contractor
Send a message via Yahoo to Bill
Shower Pan
What is the newest and best custom shower pan? Its been a bit for me, but I use to set my adjustable shower drain, then use a mud base and give about 1/4" slope towards the drain, then use a rubber membrane over the curb and up 6" on the walls, cut the corners, fold and use glue to seal the joints.
Is this still the preferred method, or is there something better?
Is it beer thirty yet
Virginia Department of Licensing
Virginia Plumbing Codes
Bill is offline
Old 09-29-2008, 01:45 PM   #2
Remodeling GC
kevjob's Avatar
Re: Shower Pan
look into www.schluter.com the kerdi shower system. We use this system on all steam showers and regular showers. You can use the pre formed tray or do a mud bed, the mud bed way is no preslope, mud your floor over lathe and tar paper and the apply kerdi directly over the cured mud bed. The only kicker is you have to use their drain.
kevjob is offline
Old 09-29-2008, 02:16 PM   #3
Max Gorietti
maxgocon's Avatar
Trade: Complete Renovations
Re: Shower Pan
I have been doing coustom shower pans for 17 years and I prefor the mud job over anything else.
Max
maxgocon is offline
Old 09-29-2008, 03:13 PM   #4
Mellison's Avatar
Trade: Home Improvement General Contractor
Re: Shower Pan
I prefer lead over rubber however not all plumbers are trained to bend a lead pan.
Mellison is offline
Old 09-29-2008, 03:48 PM   #5
Plumber / Carpenter
Bill's Avatar
Re: Shower Pan
Max
You still need something to catch the water if it leaks through the tile though. What is under the mud?
Bill is offline
Old 09-29-2008, 06:42 PM   #6
Proud Plumber
Proud Plumber's Avatar
Trade: Plumbing/Building Contractor
Re: Shower Pan
Stick with it. I do the same as you have described. I do many of them every year and have yet to have a properly done pan leak. The only thing I do different is fold corners. I never cut them, I ripped a shower out a month ago that had cut corners and was leaking.
Bill
"I'd rather die while I'm living then live while I'm dead".... Jimmy Buffett
Proud Plumber is offline
Old 09-29-2008, 07:07 PM   #7
Full Service Renovations
MAD Renovations's Avatar
Re: Shower Pan
WOW!! I am surprised that know has said "What did your tile guy say to do!!". That is usually the response from the plumbers.
MAD Renovations is offline
Old 09-29-2008, 07:16 PM   #8
Grumpyplumber's Avatar
Trade: Plumber
Re: Shower Pan
I almost responded, but saw your post..I absolutely agree - 1000%.
However, I think he may have been referring to above flood level where the liner is opened out horizontally.
Grumpyplumber is offline
Old 09-29-2008, 07:18 PM   #9
Trade: Plumber
Re: Shower Pan
If you really have the time, and are that interested in conflict..there's a nice juicy spat going on over in the marketing section...the one about negotiating price.
I betcha there's a fella or two just dyin' for a meaningful debate with you over there.
Old 09-29-2008, 07:19 PM   #10
Plumber / Carpenter
Bill's Avatar
Re: Shower Pan
Proud plumber, how do you get the folds to lay flat? I tried that a few times to no avail.
Bill is offline
Old 09-29-2008, 07:20 PM   #11
Trade: Plumber
Re: Shower Pan
I'm pretty sure he misunderstood...read my post above.
Old 09-29-2008, 07:33 PM   #12
genecarp's Avatar
Re: Shower Pan
they never lay perfectly flat, a little furring is in order
genecarp is offline
Old 09-29-2008, 07:41 PM   #13
The Grand Wazoo
KillerToiletSpider's Avatar
Re: Shower Pan
They do if you use lead.
KillerToiletSpider is offline
Old 09-29-2008, 07:57 PM   #14
Proud Plumber
Re: Shower Pan
Yes I did misunderstand.
However the folds can cause the durarock to out slightly. I usually can fur to correct or it is so slight that the area affect is in the mud tile bas and goes un noticed.
Bill
Old 09-29-2008, 08:03 PM   #15
Proud Plumber
Re: Shower Pan
LOL LOL, I get it........
Bill
Old 09-29-2008, 08:06 PM   #16
Proud Plumber
Re: Shower Pan
KTS you never cease to amaze me. I thought lead was a lost art. I have never done a lead pan. I did not even realize they were still being done. Cool!!!!!!
Bill
Old 09-29-2008, 08:16 PM   #17
The Remodeler
Splinter's Avatar
Trade: Home Remodeler
Re: Shower Pan
Notch the studs where the liner is folded so you don't bow out the cement board...
- Alex
Long Island Remodeling Contractor
Splinter is online now
Old 09-29-2008, 08:19 PM   #18
The Grand Wazoo
Re: Shower Pan
Pans are easy, wiping joints for lead services is a little more of a trick, I haven't done one of those in a few years.
Old 09-29-2008, 08:25 PM   #19
Proud Plumber
Re: Shower Pan
I honestly thought lead was out because of the harmful toxins thing. Not to mention FL is the state of Plastics, except on heavy commercial.
Bill
Old 09-29-2008, 08:40 PM   #20
genecarp's Avatar
Re: Shower Pan
True, i do remember that, the last 15years or so my guys have been using poly!!
genecarp is offline
Walk In Shower Ideas PacNWStructures Remodeling 20 11-20-2011 02:07 PM
What are they doing using my pictures and linking to my site? Mark Daniels Technology 19 08-04-2011 07:39 PM
Steam shower -who is the authority? O.C.Inc. Remodeling 9 09-30-2010 07:40 PM
tiling shower and seat rbeck3@ec.rr.co Ceramic & Stone Tile 85 10-22-2008 07:15 PM
Questions on Tiled Shower ksensen Remodeling 10 09-10-2007 09:54 AM
