Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Plumbing
Old 07-25-2007, 06:51 PM   #1
C.C.R.'s Avatar
Trade: Remodeling contractor
shower pan
Hey guys, I'm trying to find the "industry standard" for preparing a shower base for tile. I got to my site today to frame for the shower and it turns out the plumber had already installed a copper pan for the shower. There is no sloped base under this pan which, according to veteran tile setter and multi-author Mike Byrne, there should be. The way I see it the procedure is something like this:
  1. sloped sub-base (1/4" per foot)
  2. copper pan (which according to M Byrne should also be painted with roofing tar or equivelant)
  3. second sloped mud base
  4. floor tile (after walls)
Also do I need to leave my cement board off the shower floor any to avoid any water wicking? I haven't started this yet so if the above procedure is wrong, no harm done. But I would appreciate any advice you veterans have to offer.
Complete Custom Remodeling
"When Quality is Top Priority"
www.completecustomremodeling.com
C.C.R. is offline   Reply With Quote
Old 07-25-2007, 06:59 PM   #2
JPF
Trade: Handyman Services
Here's a common way on ply....a little different on concrete
http://www.ontariotile.com/preslope.html
JPF is offline   Reply With Quote
Old 07-25-2007, 07:07 PM   #3
Professional Remodeler
firemike's Avatar
If I don't use a molded pan (fiberglass, Swanstone, etc.) I use Schluter Kerdi for all my shower enclosures with a custom dry-pack base. I have been using Kerdi for the last few years, really love it.
Check it out here: http://www.schluter.com/8_1_kerdi.aspx
It has a bit of a learning curve, but I like the simplicity of it once you get the hang of it. It takes a lot of the risk out of showers leaking down the road if installed properly, and the installation is not that hard. The nice thing is you don't have to fight with the heavy rubber liner, it gives you a little more flexability in design, and you actually save time in the long run.
I just finished one up over the weekend at the cottage of one of my commercial clients.
-Mike-
Falcon Contracting
Residential - Commercial
firemike is offline   Reply With Quote
Old 08-01-2007, 10:12 PM   #4
rex
rex's Avatar
Trade: plumber
shower pans suck im pretty good at them but if its a rubber membrane pan it should be the tile guys job...
rex is offline   Reply With Quote
Old 08-02-2007, 10:01 PM   #5
Trade: Plumbing and heating
Sorry rex but, I hate answers like that. " If I don't like working with it , it's someone else's problem"
Guys I don't care whether you use copper pans , lead sheets , plastic membrane , or whatever... just read directions or find someone with the knowledge of the product you choose. Just do it right or to the best of your ability. All I ever ask is be proud of what you do right or wrong, if wrong, learn right.
C C R , floor tiles then wall tiles.
PIPES is offline   Reply With Quote
shower base C.C.R. Ceramic & Stone Tile 11 07-30-2007 09:56 AM
need to replace a garden tub with a shower MinConst Plumbing 7 07-04-2007 04:38 PM
glass block entry to shower Mr. D Masonry 10 12-04-2006 02:14 PM
Shower question joasis Plumbing 6 05-10-2006 03:27 PM
Question about shower system... Knyte260 Plumbing 59 10-24-2005 05:05 PM
