Trade: Licensed Home Improvements
Shower Floor
I'm not sure where to ask this so I thought I'd start here.About two years ago I installed a corner fiberglass shower on a bathroom redo.We put cement on the floor pressed the styrofoam floor on it then continued on the normal install.Today while fixing a slow drain, The h/o said "Oh! By the way the floor in the shower is cracked."IT IS 2"X3" in the letter J.I would like to put either a thin tub fitter floor or membrain and tile on the floor.I really don't want to rip everything out and start over any help on finding this product? It is an
Aqua glass corner shower 3 year warranty.Thanks
Capra aegagrus
Re: Shower Floor
If it's still under warranty, and you followed mfg specs for installation, I'd go that route first. The warranty might enable you to fix it right rather than applying a band-aid.
| Cross-laminated PE vapor barrier under floating floor after leveling with sleepers | sjkm | Flooring | 11 | 06-14-2009 11:03 AM |
| Wooden shower floor. | AbeBarker | General Discussion | 16 | 03-22-2009 07:55 PM |
| Tiled shower leaks...Could use any advise at all... | Jay22 | Ceramic & Stone Tile | 17 | 12-10-2008 07:15 PM |
| shower floor liner | johnthepainter | Flooring | 5 | 11-13-2008 12:34 AM |
| Sloping a shower floor | XanadooLTD | Flooring | 14 | 01-30-2008 11:17 AM |
