Trade: plumber
She Wants A Cold Shower............
The lady wants a cold shower. Here in FL cold is about 80 degrees in the summer. Not cold enough. She wants cold water. I can't seem to locate something to cool water fast enough for a 20 min. shower. I have plenty of room in the attic above shower. Any thoughts? The attic is cool, not hot up there at all.
Plumber / Carpenter
Re: She Wants A Cold Shower............
Maybe install a water cooler, then run the line to the shower?
Remodeling Professionals
Drill 'er a well, that's always cold water.....
Re: She Wants A Cold Shower............ |
I'm not a plumber or HVAC guy but I'm thinking a small (1/2 to 1 ton?) water to water heat pump would work. Use one side to heat her hot water tank and the other side to cool a cold water tank.
Trade: Home Remodeling
Build her a small bath fridge in the wall... automatically dispense ice cubes... into her bucket full of water.. She needs for 110 hot summer days in Florida sun... LOL
#7 | |
Re: She Wants A Cold Shower............Quote:
Are you sure she isn't telling you she needs a cold shower whenever you are around?...
#8 | |
Plumber / Carpenter
Trade: plumber
Older gay lady. Money doesn't appear to be an issue. All the water chillers i've seen aren't for constant pressure or won't keep up with demand. Her attic is a nice 74 degrees, it is insulated with isonene (sp) foam, so the a/c in the house cools the attic as well. I am considering putting a 400' coil of 1" pex in the attic. That should give her 17 gallons of cool water. What do you all think about that idea? It will work, or is that too hokey? I figure a storage tank would eventually leak, unless I could locate a 20 gal. corrosion proof tank, and there is already pex up there.
#10 | |
Plumber / Carpenter
Trade: plumber
boy, you are as picky as the fishing forum guys!
According to the "Mathematics for plumbers and pipe fitters 5th edition", page 216, 1" standard weight pipe has a capacity of .044 gal per foot multiply by 400' and it is 17.6 gallons. What is your formula? Pi r2h=V then convert to gallons? |
Plumber / Carpenter
Im sorry, you said 1" pex, so thats what, like 7/8"?
I was assuming that a 1" inside diameter pipe will hold 1 cubic inch of liquid per inch. Therefore 400 feet times 12 inch to the foot equals 4,800 so that divided by 231 because there is 231 cubic inch of liquid per gallon you come up with 20.779 |
The Grand Wazoo
A rooftop evap coil cooling tower sized for a six story office build should be able to keep up with one shower.
Plumber / Carpenter
I just had a thought
![]() why not burry some pipe in the ground to use just for the cold then? Sort of like thermal heating and cooling thing |
Trade: plumber
Plumber / Carpenter
She dont have a nearby pond does she?
Trade: plumber
Yeah, the Gulf of Mexico, 86 degrees in there with the Snook.
#18 |
Plumber / Carpenter
I dont know then dude. Is under the house any cooler?
#19 | |
Trade: Licensed Electrician
| Walk In Shower Ideas | PacNWStructures | Remodeling | 20 | 11-20-2011 02:07 PM |
| What are they doing using my pictures and linking to my site? | Mark Daniels | Technology | 19 | 08-04-2011 07:39 PM |
| cold air return on slab construction | LeroyJnks | HVAC | 4 | 07-11-2008 04:08 PM |
| FDA to declare cold medicines too risky for babies, toddlers | eagleandbaby | Off Topic (Non Trade) | 0 | 01-17-2008 09:36 AM |
| Questions on Tiled Shower | ksensen | Remodeling | 10 | 09-10-2007 09:54 AM |
