Sharkbite Fittings... The Truth?
Old 07-27-2008, 03:03 PM   #21
Brock's Avatar
Trade: Residential Remodeler
Re: Sharkbite Fittings... The Truth?
I would put Sharkbites on my top ten list of the best inventions in modern construction. Now if one ever does come apart inside a wall I built I will take it off the list. Until that happens I will continue saving time and money using them.
Brock is offline
Old 07-29-2008, 10:10 PM   #22
Nick1123's Avatar
Grumpy plumber... wow u spend way to much time on here for all that... i assume your retired?? or just a has been??
Nick1123 is offline
Old 07-29-2008, 10:20 PM   #23
The Grand Wazoo
KillerToiletSpider's Avatar
Rewards Points: 1,864
Using the search function takes less than a minute.
Please just continue to provide your customers with sub standard illegal installs and stop trying to use us for info.
KillerToiletSpider is offline
Old 07-29-2008, 11:29 PM   #24
Grumpyplumber's Avatar
Trade: Plumber
Nah, I have a special place in my heart for hacks that use free info from licensed professionals on false pretenses to do illegal work and dupe unknowing homeowners...especially when they come back to gloat about it after the fact.
You remind me of a fella I once knew that would use other contractors license numbers to pull permits.
Ironically, his name is Nick too...small world, coincidence I'm sure.
Grumpyplumber is offline
Old 07-29-2008, 11:30 PM   #25
Pro Plumber
Ron The Plumber's Avatar
Trade: Plumber
Rewards Points: 2,000
Did you say that about quest pipe?
Ron The Plumber is offline
Old 07-31-2008, 03:19 AM   #26
Nick1123's Avatar
grumpy plumber... maybe we are from the same area??? maybe your the 90 year old has been still grindin it out everyday pullin my permits???
Nick1123 is offline
Old 07-31-2008, 08:39 PM   #27
Service Plumber
plumberman's Avatar
Trade: Plumber
Rewards Points: 75
Nick1123 vbmenu_register("postmenu_472391", true);
you only need to fallow the rules if there is someone there to enforce them... do code officers snoop around your yard??? if not i would really not worry about it... and if they do come just play stupid... the stupid homeowner approach works everytime....
Bet that 90 year old can spell follow......
"To think for yourself you must question authority and learn how to put yourself in a state of vulnerable, open-mindedness; chaotic, confused, vulnerability to inform yourself. Think for yourself. Question authority". ..
plumberman is offline
Old 08-01-2008, 04:44 PM   #28
loneill's Avatar
Trade: appliance repair
Question
Sharkbites are certified for use on Cu, CPVC and Pex...but not the old Quest, the old grey stuff that had a class action some years ago. BUT, some have said that the Sharkbites WILL work as a good converter between Quest and say, steel threading.
I'm hoping I can have an answer on this soon...because manufactured homes in my area (out in the boonies) all seem to be fitted with Quest...I've never worked with it and no one where I live supplies it in great quantities.
Thanks for any heads up/info.
loneill is offline
Old 08-01-2008, 08:19 PM   #29
Pro Plumber
Trade: Plumber
Ok you lost me, what do you mean a converter between quest and steel threading.
Who said this?
Your answer is call a plumber, before you flood out a homeowners house. See bold highlight in your post.
Old 08-06-2008, 02:33 PM   #30
Stilts's Avatar
Rewards Points: 25
I just don't think I would trust sharkbites anywhere buried in a wall. That being said, we give the sharkbite caps to our kitchen and bath installers so that they can remove shut offs and disassemble the rooms before the plumbers get there. This saves us loads of wasted time running around just soldering on caps so the job doesn't get bogged down. We don't really trust installers to solder their own caps on, and a plumber has to be out within a day or two to do all the plumbing once the tear out is done. So I do think they have their place, just a very limited place.
Stilts is offline
Old 08-08-2008, 09:48 PM   #31
orson's Avatar
Trade: Kitchen & Bath
Rewards Points: 502
Why don't you just demo the cabinets around the existing valves and stop wasting your money on sharkbites?
orson is offline
Old 08-08-2008, 11:15 PM   #32
Brock's Avatar
In order to put the new sink base you want to drill a nice 5/8 hole for the hot and cold line to run through the ne sink base cabinet. I have seen hack jobs where the guy left the shut offs on and drilled a two inch hole in the new cabinet though.
My question is why have a plumber at all on a cabinet job? You are allowed to do a fixture change without a plumbing license. I wouldn't hire a cabinet guy that couldn't hook up a sink at the end of the job. To me it's would be like calling a tow truck because you don't know how to change your flat tire.
Brock is offline
Old 08-09-2008, 11:45 AM   #33
Herk's Avatar
Trade: Plumbing
Rewards Points: 150
That's the beauty of Sharkbites - they're removable/reusable. No waste.
There are no dumb questions - just a lot of inquisitive idiots.
Herk is offline
Old 08-09-2008, 11:49 AM   #34
Forry's Avatar
Trade: General Contractor, Remodeler
Rewards Points: 526
Here you can't do that. Only plumbers can touch plumbing. I'mnot even supposed to change a faucet.
now i am scared for my future
i've got all ten
smashed a lot of them stupidly before
-john5mt
Forry is offline
Old 08-09-2008, 11:51 AM   #35
Herk's Avatar
Trade: Plumbing
Rewards Points: 150
If you hire a cabinet guy to install a sink, you deserve whatever you get. It won't be right and it won't be pretty. I'm the guy who gets to do the plumbing right and $20,000 damage isn't that uncommon. Those new cabinets aren't nearly so pretty with that water-damaged look. Were I an insurance company, I'd have a clause about amateur-installed plumbing. There'd be a lot of folks looking for a place to live.
Here, you don't put plumbing fixtures in without a license.
Herk is offline
Old 08-09-2008, 11:57 AM   #36
Pro Plumber
Trade: Plumber
Yes your right, Hi Forry, did not even know your was from my area, till I seen Eugene, Oregon. in your profile. Call me I'll put that faucet in for you.
Old 08-09-2008, 12:31 PM   #37
Stilts's Avatar
Rewards Points: 25
You're right about it looking like crap when you hack big holes in the back of cabinets for the valves, but there's also the fact that half the time the shut offs are no good anymore, especially the hot side. Usually we're not just doing the cabinets there. It's typically at least a bathtub or shower replacement, often the pipes for the vanity need to be moved, because all our cabinets are custom built, so they end up a different size than original. There are a couple of installers that we allow to trim out the sinks and faucets, but most we don't. Too many past problems with leaks.
Stilts is offline
Old 08-09-2008, 12:38 PM   #38
Stilts's Avatar
Rewards Points: 25
We have several in house plumbers, and if we get in a time crunch and let one of the installers that we trust trim out the fixtures, one of us usually pops in to at least check it before the job wraps.
Stilts is offline
Old 08-18-2008, 01:45 AM   #39
tool junkie's Avatar
Trade: GC - Jobsite superintendent - General tool collector
Rewards Points: 75
they leak!
sorry
Hey, those push-fit fittings are great for emergency temporary repairs but yeah those rubber seals wont last. Over time they will LEAK
-----oo00oo-----
If i understood the source of my addiction I would get help,
meanwhile I'll just buy another tool today.
-----oo00oo-----
tool junkie is offline
Old 08-18-2008, 07:09 PM   #40
Service Plumber
plumberman's Avatar
Trade: Plumber
Rewards Points: 75
Originally Posted by tool junkie View Post
they leak!
sorry
What rubber seals?
Gator bite fittings, feed back please tzzzz216 Plumbing 126 04-27-2011 10:44 AM
Copper fittings wrenchman Contractor Swap 0 01-20-2008 12:35 PM
metric compression fittings????? rutalkn Plumbing 4 12-06-2007 04:39 AM
Galvanized Compression Fittings ? We Fix Houses Plumbing 25 11-10-2007 07:53 PM
