Shark Bite Fittings
Old 12-13-2006, 04:49 PM   #1
Plumber
tzzzz216's Avatar
Trade: Plumbing
Shark Bite Fittings
I just started to use the shark bite fittings on some repair work , so far I haven't had any problems with them ,(knock on wood ) Has anyone had any problems with them , and how do you like the product ?
The only easy day was yesterday !!
tzzzz216 is offline
Old 12-13-2006, 06:07 PM   #2
gitnerdun's Avatar
Trade: plumber
Re: Shark Bite Fittings
so far so good
gitnerdun is offline
Old 12-13-2006, 08:11 PM   #3
QWIKWHIP's Avatar
Trade: Heating, Cooling & Plumbing
If you guys like those you should try the Watts brand "sea-tech" fittings. They are plastic and work just as well for less than 1/2 the price.
QWIKWHIP is offline
Old 12-13-2006, 10:39 PM   #4
osborn's Avatar
Trade: Licensed Home Improvement Contractor
Ive been using them for a year. I just hope They dont leak down the road. I put some in walls and ceilings.
osborn is offline
Old 12-13-2006, 10:53 PM   #5
Plumber
tzzzz216's Avatar
Trade: Plumbing
I've used them in walls , shower valves and in 1 basement , they say their good for up to 180 psi , Before i install any i deburr the pipe then clean it with sand cloth.
tzzzz216 is offline
Old 12-13-2006, 10:53 PM   #6
mdshunk's Avatar
That basic style of fitting is what tractor-trailers have used for the air brake lines for a very long time. It's proven technology.
mdshunk is offline
Old 12-16-2006, 09:12 AM   #7
osborn's Avatar
I love them. They are costly but cheaper than a plumber. I roughed in a a laundry and bath in less than 2 hours.
osborn is offline
Old 12-20-2006, 04:40 PM   #8
plumber jay's Avatar
Trade: plumbing
Are sharkbite fittings good for kitec pipe.
plumber jay is offline
Old 12-20-2006, 08:49 PM   #9
QWIKWHIP's Avatar
Yes, they will work on Kitec. They work on all copper, pex, and pex-al-pex pipes.
QWIKWHIP is offline
Old 12-23-2006, 01:02 AM   #10
Squench's Avatar
Trade: Professional Plumber / Amateur Racer
I used them for the first time a while back, and the pipe was an underground repair on soft copper, and the pitting wouldn't allow it to seal proplerly. It dripped at first, then would SPRAY when I gave it a spin. I prefer to solder-weld all copper pipes. I hate them sharkys, but I used them once again yesterday, but I didn't like it!
Squench is offline
Old 12-23-2006, 10:06 AM   #11
Pro Plumber
Ron The Plumber's Avatar
Trade: Plumber
I don't think code allows them underground anyways.
Ron The Plumber is offline
Old 12-23-2006, 12:09 PM   #12
Squench's Avatar
From Cash Acme:
The SharkBite® Push-Fittings™ have been certified for underground applications and as a manufactured joint without access panels and they meet UPC, IPC and cUPC requirements.
Squench is offline
Old 12-23-2006, 12:14 PM   #13
Pro Plumber
Trade: Plumber
I did not look them up, I was only guessing at it, took them as a union type of fitting.
Now that I think about them, one can plumb there entire house using them, meaning they can be covered, so it will make sense. I don't use them myself. I adapt to pex when ever possible.
Old 12-26-2006, 04:33 PM   #14
claude o's Avatar
Trade: plumber
I tookthe certification class on the watts pex tubing and have used the stuff only a hand full of times , most of my builders dont want it in there high end homes maybe someday they will, my only concern is why is it only under warranty for such a short period of time?? I think it says that most of the fittings and valves are only a 2 year warranty!!
that scares me alittle bit, when i know copper will be there for decades!! its proven.
claude o is offline
Old 12-31-2006, 09:07 PM   #15
smellslike$tome's Avatar
Trade: plumbing
It seems that in my area not very many plumbing companies want to work on mobile homes, at least the mobile home owners tell me that they have a hard time getting anyone to come out. I am assuming this is because nearly all of the mobile homes I see still have polybutylene pipe. I personally would not buy another set of crimp tools or carry any PB fittings on my truck (I don't have enough space already) or want to have any liability associated with PB pipe. This may be the same thinking of others, I don't know. However, shark bite fittings are just the ticket in this situation! The HO gets what they want (and that is usually just a patch rather than a full re-pipe which is what they really need) and I don't have to be responsible for extra tools, fittings, or liability associated with PB! I'm not sure whether shark bites are rated for PB pipe or not but they work great in this application and if they should fail there is no property damage since I will only use them under the mobile home. If the leak is above the floor then I will transition to pex underneath and eleminate all PB in that particular line. They work great for me and the HOs are really happy to be able to get their problem fixed (at least until the PB fails somewhere else) and it makes me happy because I don't have to feel any guilt for refusing service to someone just because they have crappy pipe that I don't want to work on. It also makes me happy because it's very profitable.
smellslike$tome is offline
Old 05-15-2009, 03:04 PM   #16
plumbingdr's Avatar
Trade: Commercial Plumbing
no problems yet either - been using them for a couple years and leak-free. (sharkbiteplumbing.com)
plumbingdr is offline
Old 05-18-2009, 01:41 AM   #17
joelv1967's Avatar
Trade: GC, Elec, Plumb
Been using them on plastic and copper for a couple of years (since home depot start carrying them), never had a call-back yet.
Genesis 1:3 "God said let there be light, and He called me."
joelv1967 is offline
Old 11-07-2009, 07:18 PM   #18
mgd's Avatar
Trade: home improvment
Has anyone had issues with pipes turning while trying to tighten say a tub spout? If so, how did you solve it? Other than that, I swear by them.
mgd is offline
Old 11-07-2009, 07:23 PM   #19
Builder/Remodeler
ChrWright's Avatar
Trade: Builder/Remodeler
Send a message via Skype™ to ChrWright
I'm guessing you're referring to using a shark elbow for the drop to a tub/shower valve?
Are you a remodeler? Plumber? Handman?
An introduction and more detailed profile would help.
Christopher Wright, CR: President @ WrightWorks, LLC/President @ Central Indiana NARI, Named to the 2010 REMODELING Big50
www.WrightWorks.net - Facebook - Twitter - Carmel Remodeling
Indianapolis Kitchen Remodeling Contractor - You Can Get There From Here
ChrWright is online now
Old 11-13-2009, 07:01 PM   #20
Toilet Maestro
lopreste's Avatar
Trade: Bathroom remodeling
Expensive but a real time saver. Haven't had one leak yet that was connected properly
lopreste is offline
Gator bite fittings, feed back please tzzzz216 Plumbing 126 04-27-2011 11:44 AM
Shark Video - your feedback parkerfairfield Off Topic (Non Trade) 33 06-30-2008 09:04 PM
determining exact tangent point for stair fittings troubleseeker Finish Carpentry 3 04-19-2007 08:05 AM
Fittings for Air compressor hose plazaman Plumbing 9 02-18-2007 08:56 PM
Flexible Black Poly Tube and ABS Fittings? theworx Plumbing 2 05-23-2006 12:49 AM
