Trade: Plumbing
Sewer Gas At Washing Machine
First off, Iam totally embarassed to ask this question. I am a Texas master plumber and have been so for 30 yrs. I plumbed a new house around a year ago using Pvc sch 40 drain and vent lines. I plumbed the washer drain with 2"drain going directly into 3" drain some 5"away and 1 1/2" vent. The trap T's off the vertical vent close to the floor. We ran vent towards back of house about 20' making sure it had correct rise on it. Now when the homeowners
Run washer they get a sewer gas smell occasionally from washer drain. So I thought it must be vent, I cut vent going towards back of house and installed an Auto vent in attic. Which are considered legal in our area. This took care of problem for around 2 monthes, now They are getting it again. Any ideas would be greatly appreciated. Tanias55 |
Re: Sewer Gas At Washing Machine
Sounds like a question for Plumguy, - - but I don't know if I'm understanding you right, - - do you mean the 'trap' is close to the floor??, - - shouldn't it be like 48" high??, - - or at the very least, - - 6" above washer 'rim' level to prevent siphoning??
Sounds like the trap and/or vent needs to be higher. All right, - - I'll shut-up now (before I get in more trouble) and wait for Plumguy.
http://www.tr-built.com Last edited by Tom R; 10-04-2005 at 10:48 PM. |
Any chance the floor drain trap is dry?
Trade: Plumbing
Sorry I didnt make it very clear, but the washer trap is about 6" above floor with a standpipe coming out of trap to washer box at 36" off floor. There is no floor drain in laundry room. Thanks, Tanias55
Trade: Plumbing
Something I just thought of. This house happens to be last house on this branch of sewer main. I wonder if sewer main could be building up enough gas to affect washer drain since its the most water going down sewer at a time. I might try installing 4" running trap on sewer coming out of house?
Trade: Commercial Equipment and Facility Maintenance
Could the vent pipe have been damaged in final construction, cut, drilled, broken within the wall? Is the smell REALLY sewer gas? Could this be water (sulfer ) -or some chemical ?
#7 | |
Trade: Plumbing
Re: Sewer Gas At Washing MachineQuote:
#8 | |
Plumbing/Mechanical Insp.
Trade: plumbing/mechanical/building inspector
That is my 1 cent on this topic. Good luck and let us know what you find out Justin |
Hey Tania, - - I'm not a plumber, I'm a carpenter (who thinks he's a plumber too), - - so feel free to 'laugh' at my guesses (Plumguy always does
http://www.tr-built.com |
Just read back and realized Moscow's pretty much sayin' the same thing. Seems like the trap should only be about somewhere between 10 to 20 inches below the standpipe inlet.
#11 | |
Chow for now Justin |
#12 | |
Sounds like them damn washin' machines must be the 'opposite' of humans, - - what with that damn 'dump cycle' rate and all!!
http://www.tr-built.com Last edited by Tom R; 10-05-2005 at 07:07 PM. |
#13 | |
One drink and your colin is clean |
#14 | |
Trade: plumbing and heating
I did not read the other posts ...so, maybe you have it solved. But, here the stand pipe out of the trap on a washer has to be between 18"-30". So if your'es is longer than that it might be siphoning the trap....considering the force(inertia) that a washer's pump creates. |
#15 | |
#16 | |
#17 | |
| Milling Machine Techniques | BlackGold | Concrete & Paving | 1 | 09-08-2007 04:17 PM |
| Drain for ice machine | tzzzz216 | Plumbing | 4 | 06-25-2007 01:34 AM |
| General purpose machine | Vermaraj | Excavation & Site Work | 10 | 03-21-2007 01:09 PM |
| Sewer stub | Moscow | Plumbing | 2 | 02-27-2007 05:18 PM |
| Washing Machine/Floor Vibration Problem | NHCharger | General Discussion | 13 | 01-18-2006 07:52 PM |
