Sewage Pipe Grade
Old 08-27-2006, 06:23 PM   #1
gtdail's Avatar
Trade: Lisc. General Contractor
Rewards Points: 77
Sewage Pipe Grade
Not a plumber myself but I helped a friend get water hooked up on a mobile home he bought could anyone tell me at what grade/slope the plumbing needs to be hooked up at to drain to the septic tank? Thanks for your help.
gtdail is offline
Old 08-27-2006, 06:27 PM   #2
Custom Builder
Glasshousebltr's Avatar
Rewards Points: 2,000
Re: Sewage Pipe Grade
Between 1/4 to 1/2 inch a foot.....1/4 being preferred.
Bob
Bob
Glasshousebltr is offline
Old 08-27-2006, 09:26 PM   #3
Teetorbilt's Avatar
What Bob said. If you can get away with a higher pitch, go for it. 1/4" in 12 is minimum, more pitch = less problems.
Albert Einstein
Teetorbilt is offline
Old 08-27-2006, 10:18 PM   #4
Tom R's Avatar
Rewards Points: 2,036
I don't know about 'more pitch = less problems' . . .
Too much pitch leaves the solids behind, - - 1/4" is the ideal pitch.
Tom R is offline
Old 08-27-2006, 10:48 PM   #5
Moderator
Double-A's Avatar
Grade on 4" and smaller is generally 1/4" per foot. Best bet is to check with your AHJ (local inspector).
Although it may not kill anyone if this is not done properly, I would suggest having a licensed plumber do this work. Bellies, backfall, lack of cleanouts or misplaced cleanouts can all lead to serious and costly problems down the road. A plugged sewer is no ones idea of a fun filled weekend.
New York Times, July 20, 2006
Double-A is offline
Old 08-27-2006, 10:53 PM   #6
Custom Builder
A plugged sewer can create a lot of crap.
Bob
Bob
Old 08-27-2006, 11:09 PM   #7
Teetorbilt's Avatar
Tom, over 90% of what flows through the pipe is water. Think about it. Peeing, showering, washing dishes, laundry, all water.
The worst problem has always been grease. It will stick to the walls of a pipe and restrict the flow. I have seen clumps the size of basketballs in wetwells, they can shut down a pumping stations pump.
Albert Einstein
Old 08-28-2006, 06:21 AM   #8
Joasis's Avatar
Rewards Points: 1,302
Has anyone read anything about septic systems designed to take only black water into the tank and field, and then what do they do with the grey water? The point being a perfect system will never cause problems, but grey water is what kills the bacteria in the system.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Insulated Concrete Homes / ICF's
My Facebook Page
Joasis is offline
Drain Pipe denick Excavation & Site Work 18 07-12-2009 03:41 PM
Gas Pipe Question.... drbigfresh Plumbing 9 02-28-2007 02:51 PM
Using Flex Pipe dirt diggler Pool Construction & Enclosures 8 02-25-2007 03:30 PM
flue pipe soot problem magnum General Discussion 4 12-15-2005 09:17 PM
How to trace gas pipe? karma_carpentry Carpentry 15 11-30-2005 10:47 AM
