Sewage Ejector Pit - Plumbing - Contractor Talk
Sewage Ejector Pit
Old 06-21-2010, 08:21 AM   #1
Project Manager
CookeCarpentry's Avatar
Trade: Project Manager
Rewards Points: 2,016
Sewage Ejector Pit
Ok, so the wife approached me with yet another project. Installing a wet bar in our walk-out basement.
Basement currently has a full bathroom. The proposed location for a sink and diswasher is on the opposite side of the room (about 30 feet away).
I'm figuring that I need to use a sewage ejector pit for the sink and dishwasher. My problem is, I can't seem to find a way to size for just a sink and DW (pit size and lift).
If possible, a pit would necessetate 8' of lift and about 12' of vertical run in a ceiling joist bay.
Any suggestions or recommendations?
CookeCarpentry is offline
Old 06-21-2010, 10:37 AM   #2
Moderator
Double-A's Avatar
Rewards Points: 2,000
Re: Sewage Ejector Pit
You're not gonna like my suggestion.
Get a plumber involved. They make undercounter setups just for this situation, or you can put the thing in the concrete, but in either case, you have to deal with more than just waste, you have to deal with venting. If you put the thing in concrete, be sure your water table never rises too much, cause if it comes up before this sump is full, its gonna try to float up and out of the hole. Ewww.
Some model codes require this have its own separate vent running all the way out without tying into another vent, minimum 2" in size. You also need to be sure to isolate the unit and the pipes for it properly or you're gonna wake the dead when it kicks on. Its gonna rumble the ceiling joists like crazy.
Oh, couple more things, dedicated GFCI circuit, check valve, union in the waste and vent lines for service....
Plumber. These take experience or they are more of a pain they they are worth.
New York Times, July 20, 2006
Double-A is offline
Old 06-21-2010, 10:40 AM   #3
Project Manager
That's exactly what I was looking for.
Separate (dedicated) vent is no problem as closets are stacked above the area. Knew about the GFCI dedicated circuit, etc.
Did not know they make under-sink models...do you know a manufacturer? Or a link?
EDIT: found a few manufacturers online. Anyone with experience with an undersink unit? I'm not worried about isolating the drain and vent lines in stud/joist bases, but with the actual unit sitting in a cabinet.
Old 06-22-2010, 07:59 PM   #4
The Grand Wazoo
KillerToiletSpider's Avatar
Rewards Points: 1,884
When it fails it's gonna ruin the cabinet.
I may be going to hell in a bucket, but at least I'm enjoying the ride.
KillerToiletSpider is offline
Old 08-27-2010, 07:33 PM   #5
tomgoral's Avatar
Trade: Realtor
I would stay away from ejector pits. I worked on them long enough to hate them.
tomgoral is offline
Old 08-27-2010, 07:43 PM   #6
Construction Connoissuer
CCCo.'s Avatar
Trade: Construction Remodeling - Renovations Repairs
Location: Kirklin, IN "Proudly Serving Central Indiana Area"
Rewards Points: 1,320
Ok, who let the realtor in ?
James Crow - Crow Contracting Company, LLC - Central Indiana Remodeling Contractor
Facebook l Youtube l Merchant Circle
Home, Kitchen & Bath Remodeling - ~ - Facility Maintenance & Repair Solutions
Want to contact us? - Call ~ 765.279.8271
CCCo. is offline
The Following User Says Thank You to CCCo. For This Useful Post:
CookeCarpentry (08-28-2010)
Sewage Diversion green Excavation & Site Work 9 06-27-2010 08:21 PM
Neighbors sewage running into my pond 21gun General Discussion 75 03-18-2010 08:51 PM
Sewage water damage fallout-Advice needed Heritage General Discussion 5 09-18-2009 11:27 PM
Liberty sewage pump reveivl Plumbing 6 09-13-2008 12:27 AM
Basement Bathroom - Sewage Ejector highpeaks Plumbing 1 07-28-2008 05:45 PM
