Kitchen & Bath Man
Trade: Residential remodeler, master carpenter
Setting A Tub - In Concrete Or Foam?
The latest beer time argument is on the best way to set a tub. My plumbing friend Zippy sez the best way is in spray foam. My other plumbing friend, Not-So-Zippy thinks concrete is the way to go.
As a carpenter, the idea of a few hundred pounds of concrete on my new floor is a little disconcerting - especially considering the weight of the tub, water and the guy using the tub. What does the forum think? Concrete or foam? Or is there a third, better way?
Jim Edgar StarCraft Custom Builders jime@starcraftcustombuilders.com http://starcraftcustombuilders.com |
Doofenshmirtz Evil Inc.
Re: Setting A Tub - In Concrete Or Foam?
I always do what the tub manufacture recommends.If given a choice I would use foam.
in texas with framing and cornish people will do it for 3.00 a foot. What do yall think about that? Just laber |
Its all ball bearings
Trade: Tile
This has been discussed in detail before. Don't be afraid of the search button!
http://www.contractortalk.com/f9/set...urabond-68061/ http://www.contractortalk.com/f18/do...ceptors-65033/
Angus L+M+O+P=C ![]() "Promise only what you can deliver. Then deliver more than you promise" |
I like Green things
liquid plutonium, gives the tub a neat glow.
Warner Remodeling ll Auburn Indiana Remodeling ll Dekalb County Remodeling ll Custom Woodworking Auburn Indiana Warner Remodeling Facebook |
Yeah...But don't buy it at Home Depot.
I like Green things
I converted a mr. juicer, it actually powers my delorean and sets my tubs in.
Trade: Electrical & Carpentry
Most shower bases that I have put in have in their instructions to set it in a Mortar base. I have a Swanstone to put in next week and I have the Instructions right in front of me & they recommend them to be nestled in a mortar bed (quickrete) . 1/2" for the smaller bases & 1" for the bigger ones The shower base should be pushed down in to the bed.........................
I haven't come across any yet that recommend foam. It would be easier to do but will it be set like Mortar? |
| The Following User Says Thank You to mrmike For This Useful Post: | essrmo (01-23-2010) |
Trade: Construction
I have always used a concrete base on all tubs and showers i have installed. I wouldn't even consider expansion foam as it don't give the support thats required and i have never come across one company that says it should be done this way but i have seen a few that say don't do it this way. Every shower tray i have ever seen that has been mounted with foam has failed early on in it's life.
KemoSabe
Structolite by USG.
__________________________________ "Walking the fine line between production and perfection" __________________________________ |
![]() Trade: helping people avoid problems with toxic materials
Re: Setting A Tub - In Concrete Or Foam?Last edited by FStephenMasek; 08-18-2011 at 07:36 AM. |
The Grand Wazoo
Vaseline.
Maxi-Pier Tech
Trade: foundation specialist
Mortar = 3 parts sand, 1 part cement
Concrete = 2 parts sand, 1 part aggregate (rock), 1 part cement. ever seen a tub set in CONCRETE?
| The Following User Says Thank You to essrmo For This Useful Post: | MarcD (01-23-2010) |
Trade: Specializing in residential remodeling
Spray foam
![]() Concrete ![]() Plaster of Paris ![]() Mortar mix ![]() But always, yes ALWAYS follow manufacturers specifications |
Complete Home Services
Trade: General Contractor / Remodeling
Mortar.
We have always used mortar for 30 years.
A few years ago we sold a spec home we were building while we were still framing it. Real nice couple and the husband weighed over 400 lbs. He was really worried about what we were going to put under the tub, because he had a bad experience where they didn't put anything under the fiberglass tub/shower unit. I reassured him that we always put in a nice mortar bed and the tub wasn't going anywhere and would be rock solid. So I don't think spray foam would cut it in this situation, and would never use it because you never know who is going to use the tub. |
Trade: carpentry,electrical,plumbing,tile&stone,painting,
Any instructions we have ever read called for either mortar or plaster.Dont forget to put down felt papper and wire lath first.Neither will stay bonded to plywood for an extended period.
bathroom guru
Depending on the tub - drypack with some thinset on top
#18 |
Master-Pro-Plus
Trade: Master Plumber/Pipefitter,General Contractor, Plus
Hello guys, Definitely check manufactures recommendations. If you are to use anything, use a dry substance, perlite or a softer foam. Some tubs or tub/showers recommend nothing at all. I have been to a few manufacturers plants in my time and I have to say AKER fiberglass is one of the best. There bases are manufactured with balsa wood in between the glass and nothing is needed to set this in. We watched a tub/shower unit be lifted with chains through the sides and two people inside jumping up and down and the chains slowly ripped through the sides before the bottom ever thought of giving away. So just my opinion, but be sure what you set these in. Nothing that sets up, you will end up with a crack in the tub, or chemical bleed through and then, forget any kind of warranty. Good Luck
#19 |
I like Green things
I just installed an Aker, nothing in the directions about setting it in something.
Just from drilling the holes for the controls, that is one tough tub.
#20 |
Chief Toilet Mover
Trade: Bathroom Remodeling
Re: Setting A Tub - In Concrete Or Foam? |
| Spray foam under a slab for insulation -- | Mike Finley | Construction | 22 | 01-10-2010 02:39 PM |
| Tampa, FL. Concrete Forklift Ramp Needed | phattractor | Help Wanted or Looking For Work | 0 | 02-10-2009 02:26 PM |
| foam spray gun vs canned foam | 72chevy4x4 | Tools & Equipment | 4 | 12-03-2008 08:30 AM |
| exposed deck w/EPDM on concrete (no pitch) | kellry27 | Decks & Fencing | 0 | 09-22-2008 09:03 PM |
| attaching metal lath to poured concrete walls with foam | michiganmason | Masonry | 0 | 02-12-2008 04:26 AM |
