Septic Tank Smells A Bit Lately
Old 03-24-2008, 11:09 AM   #1
robertc65's Avatar
Trade: Former Electrician
In the last week or so I have been getting a whiff of stink from my septic tank when I walk outside. It's not very strong, but I have never smelled it before. I had it emptied out about 6 months ago so I know it's not over flowing with solids and at the time the septic guys said it looked to be in perfect shape. I'm wondering if the fact that we have had so much rain recently and the ground is pretty much saturated including the area above the drain field. Could this cause some odor?
Thanks
Rob
robertc65 is offline
Old 04-03-2008, 06:31 PM   #2
lenlaf53's Avatar
Trade: Septic Designer/Installer/Soil Tester/Maintainer
Re: Septic Tank Smells A Bit Lately
It may take some time for the scum layer to reform in the septic tank. Once it forms, it will block some of the smell. The odor is normal, just think of what is going on in there. Try to reduce large water uses such as laundry and see if this helps.
lenlaf53 is offline
Old 04-03-2008, 06:34 PM   #3
mdshunk's Avatar
When it's been raining a lot in the recent past, you will get a whif every once in a while. The system just won't perk that well in sopping wet ground. No big deal.
mdshunk is offline
Old 04-03-2008, 08:22 PM   #4
cleveman's Avatar
Trade: custom home building
Are you going outside to pass gas? This may be what you are smelling.
cleveman is offline
Old 04-03-2008, 08:47 PM   #5
painterman's Avatar
Trade: Historic Restorations
If you can smell it ,there is a very good chance that something is wrong. Pull the tops of the tank and have a look. The tank should not be filled to the very top(above the exit pipe). Sounds(smells) like the leach field is not draining away.
Good luck
painterman is offline
Questoin about septic in VA Project53 Construction 19 04-04-2008 06:25 PM
Installing Septic System SMKFULLER Excavation & Site Work 8 04-03-2008 09:23 PM
Heating Oil Tank Venting RenaissanceR HVAC 1 01-02-2008 07:41 PM
New septic system silvertree General Discussion 14 11-26-2007 07:36 PM
septic tank replacement loogout1 Excavation & Site Work 14 10-05-2007 08:23 AM
