Trade: renovator
Second Floor Water Heater Drip Pan And T&P Drains
Gentlemen,
I think I posted a thread about this a couple of years ago, but, frankly, I've never been completely satisfied with this subject, so here goes again. You've got a two storey home with full basement. Second storey bathrooms and an electric water heater in a service closet on the second floor. The heater must sit in a drip pan and the drip pan must have a 3/4" drain. The T&P valve must also have a 3/4" drain and cannot terminate in the drip pan. Both must separately go either outside or drain into another drain, like a floor drain or a fixture. In places where it's -10F two months of the year, noone wants to terminate outside. The second floor bathrooms don't have floor drains. This is why I personally have yet to see a second floor water heater installed with every aspect of code satisfied. Maybe I just hang out in the wrong places. So I'm working on a place, we've got the first floor ceilings and second floor walls open, it's really the right time to bring this up to code - - but frankly it looks like the "right" way to do it is to run two 3/4" drain lines all the way down to the basement to the floor drain or the sump. Which, if you ask me, completely defeates the purpose of the drain lines being visible so people can detect T&P problems, 'cause noone's gonna be checking out this dark corner of the basement regularly to see if there's a drip from these lines. Maybe I'm just missing somthing. Thanks. |
Thom
Re: Second Floor Water Heater Drip Pan And T&P Drains
I've done them where we set the water heater on a standard shower pan that is plumbed into the waste/vent system. The T&P terminates above the flood level rim of the shower pan as does the necessary trap primer.
It's simple, cheap, and the inspectors have looked favorably on the installation. |
Agreed with above post--------------vent
Trade: renovator
Ya, I was thinking just turn the closet into a mini-shower. Mine's not a standard shower pan size, but what the heck - so I'll mud a 20" shower. Doesn't have to be pretty.
By definition I've got the cold water line in there - perfect spot for a pressure-drop primer, it'll get acutated everytime anyone turns anything on in any bathroom. Last edited by bob_cntrctr; 07-18-2009 at 01:32 PM. |
Professional Instigator
I do it like Tom suggested or use a condensate pump.
Trade: renovator
Ho ho - shower pan - non-standard size - - 20" x 20" - - aha! A laundry tub! Cut down to a few inches tall - drain built in ready to go, no mudding - love it.
Trade: renovator
Just to update and close off this thread - I ended up mudding a traditional shower pan in the service closet and connecting a full drain with vent, then adding a trap primer on the toilet supply line. A 9" curb across the front of the closet and 6" of tile up the wall and curb. Nice little set up - everything can just drain into the floor of the service closet 'cause it's a shower.
| The Following User Says Thank You to bob_cntrctr For This Useful Post: | MACPLUMB (08-02-2009) |
#8 | |
the pipe master
Trade: plumbing, solar
Why can't you simply oversize and insulate the drains on the outside?
Plumber, Repiping, Replumbing, Leak Detection, Solar Water Heater, Polk County Plumber, Lakeland Plumber, Winter Haven Plumber |
| T&p | rex | Plumbing | 5 | 09-17-2007 01:35 AM |
