Trade: Professional Handyman
Sealing Floor Drain?
Small utility room in commercial building being renovated into a work station. Has CI floor drain in slab. CI is rotted away to about 2" below surface.
Owner wants drain plugged permanently. Floor will be covered in VCT. I'm thinking a handful of hydraulic cement and over top with leveler. Any flaws in my plan?
The cat box ain't gonna clean itself. |
Trade: Construction
Re: Sealing Floor Drain?
Best bet would be a cap/plug if you can cut down around the pipe. Something like below would work well.
![]() http://webstore.petersenresources.co...PipePlugs.aspx Last edited by BCConstruction; 08-09-2009 at 08:20 PM. |
Trade: custom home building
I recently used something similar to that pictured above and filled with sacrete. Tiled over the top.
#4 | |
Trade: plumbing
Re: Sealing Floor Drain?Quote:
#5 | |
Pompass Ass
If you put too much hydraulic cement in it, it may get into the main building drain, that is why you stuff rockwool into it 1st. |
Trade: Flooring & Remodeling
I'm replacing a 5 ft stardard tub with a tiled showerpan . Is it better to move the drain over a bit, and if so how far? Or should i just leave it where its at and slope the pan toward drain?
#7 | |
Pompass Ass
Move the drain to the middle of the shower floor and slope the floor at 1/8" - 1/4" per foot towards the drain. |
Trade: Construction
Re: Sealing Floor Drain? |
#9 | |
Thanks for the info. http://www.finaltouchflooring.net |
Pompass Ass
Make sure your plumber puts sleeves on the copper pipe, it cannot have direct contact with masonry.
Had some free time today and finished the showerpan & seat. Used Oatey 40 mil pvc liner, Sakrete bed, Hardie 500 1/2", Concrete blocks for seat.
| sealing clay tile? | look171 | Masonry | 6 | 08-14-2009 04:31 PM |
| Sealing Pavers | bob14-0 | Landscaping | 8 | 07-27-2009 05:01 AM |
| Sealing up an Energy Star home | monticellohomes | Green Building | 18 | 01-28-2009 10:03 PM |
| Sealing a exterior door | N.Schiffer | Finish Carpentry | 0 | 11-05-2008 08:11 AM |
| Grout Width and sealing. | jritkes | Flooring | 6 | 09-28-2008 08:23 PM |
