Custom remodeling
Trade: home remodel
Rubber Gasket For Shower Drain....HELP
Installed a new fiberglass shower pan, with the brass no caulk drain. I have tryed 2 different rubber gaskets that go into the drain, both seem to fit the 2" PVC in the floor a little loose. When I screw down the jam nut, it doesnt seem to seal, I can see that its not tight around the drain pipe looking down at it with a flashlight. The drain pipe is 2", pan is set on concrete floor. This is a remodel, the old pan that was in there had no leak problem, client wanted new. Am I missing something, is there a "trick" to this? Or is there a better drain to use. Thanks for any help...
#2 | |
Professional Instigator
Re: Rubber Gasket For Shower Drain....HELPQuote:
Trade: plumbing2heating
Try calling your local plumber,this is an easy fix and if i tell you it will take work away from a guy who earned something called a license.I dont mean to be rude but you guys need to be stopped,plumbing is not a hobby.
| The Following 2 Users Say Thank You to ct plumber For This Useful Post: | bergdesign (04-05-2009), protechplumbing (04-07-2009) |
Custom remodeling
Trade: home remodel
just looking for a little help, not a better than thou reply...
Re: Rubber Gasket For Shower Drain....HELP |
| The Following User Says Thank You to ct plumber For This Useful Post: | protechplumbing (04-07-2009) |
Trade: carpenter/ handyman
You may get lucky & get 10 or 20 yrs without a problem. Better hire a real pro now to be safe.
I repaired a bathtub drain leak recently that the builder's "pro" had used the appropriate rubber washer under the tub & plumbers putty under the flange above the tub. It took about 12 yrs for it to start leaking. The tub is upstairs, so you can guess the rest. Steve |
Pro Plumber
Trade: Plumber
Apply some silicone to a new gasket, it will allow the gasket too squeeze that much more tighter around the pipe. Glad I could help you out.
Pro Plumber
Trade: Plumber
This tool that comes from Oatey is the best tool to use on no caulk drains.
Ron,
Kudos to you on your well trained cats. They are certainly ready for the Feds when they come with our new President's orders to take (or die trying, I'm sure) your guns. Steve |
The Grand Wazoo
Throw the rubber gasket away and yarn and pour a lead joint.
the pipe master
Trade: plumbing, solar
Plumber, Repiping, Replumbing, Leak Detection, Solar Water Heater, Polk County Plumber, Lakeland Plumber, Winter Haven Plumber |
The Grand Wazoo
Neo is correct.
DRIFTWOOD
Trade: GEN CONTR.
Pouring lead in plastic? Never heard of this. Learn something new each day.
Don't think I'd share it with a S.F. PLUMBING inspector! |
the pipe master
I thought you were being sarcastic. Your'e serious?
Why will the plastic NOT melt when the molten lead hits it?
The Grand Wazoo
Cold pour it.
#18 |
DRIFTWOOD
Trade: GEN CONTR.
How about packing lead wool over oakum ? NAW
#19 |
The Grand Wazoo
Lead wool does not meet code, all lead joints must be made with molten lead, single poured.
#20 |
the pipe master
| Rubber roof hole | Mitch M | Roofing | 39 | 04-02-2009 12:18 PM |
| How close to the drain should the trap be? | drb9 | Plumbing | 17 | 11-04-2008 07:59 PM |
| small rubber roof repair | jclem | Roofing | 2 | 10-28-2008 09:10 PM |
| French drain | Bill | General Discussion | 12 | 09-09-2008 01:01 PM |
| odd find for drain pipe | 72chevy4x4 | Plumbing | 9 | 11-06-2007 10:48 PM |
