Routing Water Heater Drain Pan Drain Line.
Old 05-19-2008, 05:13 PM   #1
bob_cntrctr's Avatar
Trade: renovator
Gentlemen,
Two new bathrooms on second floor - installing an electric water heater up there with them, in a (accessible!) service closet in one of the bathrooms.
In the "excess and zeal" theme, I wanna go beyond your simple drain pan. They're useless for all but the most sedate leak. Basically imagining doing this service closet up like a shower stall with a floor drain.
Question is where to run the drain.
I've seen drain pans piped to dump open into an existing floor drain, like in a basement. But never hard-plumbed into the DWV system. One problem I foresee is a dry trap - in theory this thing will never get water to keep a trap full.
bob_cntrctr is offline
Old 05-19-2008, 05:19 PM   #2
Professional Instigator
rbsremodeling's Avatar
Re: Routing Water Heater Drain Pan Drain Line.
Originally Posted by bob_cntrctr View Post
Gentlemen,
In the "do it right" theme, I wanna go beyond your simple drain pan. They're useless for all but the most sedate leak. Basically imagining doing this service closet up like a shower stall with a floor drain.
They will tee off the plumbing for the new bath and install a drain for the water heater
or
Use an ac condesate pump, raise the heater on a box and have the drain pan dump into the condensate pump you can then route the tubing from the pump where necessary for the run off
Both ways are legal here
rbsremodeling is offline
Old 05-19-2008, 05:42 PM   #3
Trade: renovator
Originally Posted by rbsremodeling View Post
... tee off the plumbing for the new bath and install a drain for the water heater ....
You mean:
a) Above the bath drain trap so heater drain doesn't need a trap?
Or
b) below the bath drain trap and install a trap on the heater drain? And if this way, how to avoid a dry trap since this should normally never get water?
Old 05-19-2008, 05:45 PM   #4
The Grand Wazoo
KillerToiletSpider's Avatar
Put a trap primer on the drain, or fill it with vegetable oil.
KillerToiletSpider is offline
Old 05-19-2008, 05:51 PM   #5
You mean:
Or
All the drains are at the same height in theory with adequate pitch the drain for the heater has its own trap. I don't really think you will have a dry trap scenario.
But I will note I am not a plumber. Ps they will be some more answers to your question soon I assure you
Old 05-19-2008, 05:52 PM   #6
genecarp's Avatar
im no plumber, but would a checkvalve before the trap work?
genecarp is offline
Old 05-19-2008, 06:03 PM   #7
Trade: renovator
All the drains are at the same height in theory with adequate pitch the drain for the heater has its own trap. I don't really think you will have a dry trap scenario. ...
Good point. Proper selection of height & pitch could mean bath keeps heater trap full. Cool.
Old 05-19-2008, 06:09 PM   #8
I like the way everyone just skipped
right on past the only plumber in
the thread.
neolitic is offline
Old 05-19-2008, 06:11 PM   #9
Trade: renovator
Put a trap primer on the drain...
Ya, probably the right way to do it. Is vegetable oil code?
Old 05-19-2008, 06:14 PM   #10
the thread.
Plumber?? we don't need not stinkin plumber
Old 05-19-2008, 06:15 PM   #11
Pro Plumber
Ron The Plumber's Avatar
Trade: Plumber
Gentlemen,
The T&P drain can not be directly connected to a drain, it has to be indirectly connected with an air gap.
Ron The Plumber is offline
Old 05-19-2008, 06:16 PM   #12
The Grand Wazoo
On new construction in Illinois you would have to install a trap primer, if it is existing then vegetable oil is in the code.
I have no idea where you are located, so you would have to check your local code.
Old 05-19-2008, 06:18 PM   #13
Can you use, we call them studavents? The in wall vent thingamagigs
Old 05-19-2008, 06:23 PM   #14
Pro Plumber
Trade: Plumber
You can drain to and existing drain but you have to have an air gap.
Old 05-19-2008, 06:24 PM   #15
Kitchen and Bath Expert
Paul Joseph's Avatar
Trade: remodeling contractor
There is a product that goes in the pan that shuts off the supply as soon as the water is 1/2 inch deep. That solves the entire problem and no drain needed
Paul Joseph is offline
Old 05-19-2008, 06:29 PM   #16
neolitic is offline
Old 05-19-2008, 06:31 PM   #17
The Grand Wazoo
What happens when that fails?
Old 05-19-2008, 06:33 PM   #18
We use those on ac units and water heaters and believe it or not they fail for various reasons
Old 05-19-2008, 06:37 PM   #19
22rifle's Avatar
Trade: Plumbing & HVAC, I specialize in Hydronic Heating and more specifically in Radiant Floor Heating
Gentlemen,
Don't do this the hard way man. Put in your plain old floor pan and then one of these:
http://www.wagsvalve.com/
There are similar models available from other manufacturers.
22rifle is offline
Old 05-19-2008, 06:38 PM   #20
22rifle's Avatar
Which brand are you using?
How are they failing?
22rifle is offline
Hot Water Heater 3Kings Plumbing Plumbing 8 02-03-2008 11:33 PM
Insulation water heater and hot water lines tzzzz216 Plumbing 7 02-01-2008 07:08 PM
REALLY fast electric water heater rhinoguy Plumbing 8 04-09-2007 11:37 PM
LP water heater on NG? rhinoguy Plumbing 4 02-08-2007 08:55 PM
